Questions about utec
Old Feb 20, 2008 | 09:09 AM
gmx's Avatar
gmx
Default Questions about utec
I have one question im confused i have a utec and a full build engine with
greddy tt the problem is the factory ecu that i have is for a/t car but my car
is m/t. is it fine to install that ecu with utec on my engine??
Old Feb 20, 2008 | 02:00 PM
JonnyC's Avatar
JonnyC
I don't think the UTEC cares (or even knows) whether you have an auto or manual transmission. It just controls the injectors and timing based on RPM and load - doesn't mess with any shift points.
However, this is coming from someone who doesn't even own one yet.
Old Feb 20, 2008 | 02:15 PM
garym's Avatar
garym
If he's trying to put a factory ECU that is for an automatic in a car with a manual, I'm pretty sure it won't work.
UTEC doesn't care, but factory ECU does.
Factory ECU on a Z has shift light and features specific to a manual, and that will differ from an automatic.
my 2-cents
Old Feb 20, 2008 | 05:02 PM
gmx's Avatar
gmx
thats bad so i will continue searching for a m/t ecu
thanks guys
Old Feb 20, 2008 | 05:09 PM
gmx's Avatar
gmx
found also a factory ecu but its for the rev up engine and my engine is not
will it work fine with my engine??
Old Feb 20, 2008 | 09:19 PM
JonnyC's Avatar
JonnyC
What happened to your car's ECU? I assume you can't use that one?
Old Feb 21, 2008 | 06:29 AM
gothchick's Avatar
gothchick
If you swap ECUs, make sure you get the keys that go with it, or the car won't start... You could always get it reflashed though.
issyz
Jul 2, 2017 03:04 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
