Coolant control valve ?
Old Feb 21, 2008 | 04:29 PM
JCstart's Avatar
JCstart
Default Coolant control valve ?
anybody tried this ? the coolant control valve...
good... bad.... any comments ?
and for the police search...I found nothing... if you found anything, just tell us...
Old Feb 21, 2008 | 04:34 PM
chefsz's Avatar
chefsz
haha nice post
this info has to be in there somewhere
the valve stops the coolant flow to the plenum near the throttle body, allowing for hot or cold starts and adjusting idle and what not
turning this off will keep your plenum cooler, possibly increasing butt dyno hp
Old Feb 21, 2008 | 04:36 PM
raf84ny's Avatar
raf84ny
The CCV allows you to selectively heat (or not heat) the plenum assembly. With local weather temperatures below 55'F the valve is left open. In warmer weather the valve can be closed for maximum thermal benefits.
This is from the MotorDyne website.
http://www.motordyneengineering.com/350Z.htm
Rev_Night
Nov 7, 2020 06:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
SharX59
Sep 27, 2015 09:23 AM
