TB mod= worse performance???
Old Mar 28, 2008 | 09:04 AM
GrayG35's Avatar
GrayG35
Default TB mod= worse performance???
i got my car tuned a few months ago by uprev and they did that thing that keeps my throttle body open 100% all the way to redline, and set my afr's to 12.8. Now for some reason it feels as if my car pulls better with only about 3/4 throttle as compared to WOT.... could it be that i am getting too much air in and maybe nissan made the TB close about 20% up top for a reason??? even though shouldnt the tune have been able to correct the "bogging" with the extra air????
Old Mar 28, 2008 | 11:08 AM
HondaKiller's Avatar
HondaKiller
the tune should have compensated for the extra throttle. Classic case of you getting used to things and not noticing minute differences that stand out when you first upgrade.
Old Mar 28, 2008 | 01:06 PM
GrayG35's Avatar
GrayG35
if i had just got used to it then why would 3/4 pedal feel a bit faster than WOT?? idk... thanks for your input. anyone else have any ideas?
Old Mar 28, 2008 | 01:10 PM
BabyZiLLa's Avatar
BabyZiLLa
A/F ratio is off at WOT so the ECU is pulling timing?
All I can think of.
Old Mar 28, 2008 | 08:07 PM
GrayG35's Avatar
GrayG35
anyone else???
Old Mar 29, 2008 | 10:01 AM
BabyZiLLa's Avatar
BabyZiLLa
Originally Posted by GrayG35
anyone else???
Your welcome
Old Mar 29, 2008 | 10:16 AM
rx7/350z's Avatar
rx7/350z
too much air is not the problem. lOl! If your car was tuned to 12.8 a/f on wot dyno runs and that is what it still is, your ecu is probably pulling timing. Im guessing you don't have a wideband so getting back on a dyno is your best bet.
Old Mar 29, 2008 | 10:29 AM
350 Rookie's Avatar
350 Rookie
so wait. why are you running rich again? FI?
Old Mar 29, 2008 | 11:27 AM
GolfinZ's Avatar
GolfinZ
12.8 is a bit rich for N/A...ask them to take some fuel out
Old Mar 29, 2008 | 05:02 PM
GrayG35's Avatar
GrayG35
Originally Posted by BabyZiLLa
Your welcome
thanks, for your input i didnt meen for it to sound like that
Old Mar 29, 2008 | 05:03 PM
GrayG35's Avatar
GrayG35
ya thats what i said, but the guys at uprev told me that 12.8 was a good place afr for bolt ons??? I think 13.0-13.2 would be much better....
Old Mar 29, 2008 | 05:51 PM
GolfinZ's Avatar
GolfinZ
I agree. Did you get a dyno graph with afr?
Old Mar 29, 2008 | 10:23 PM
GrayG35's Avatar
GrayG35
yes i did. im supposed to be getting another dyno done tomarrow by another shop so if i do i will post up the dynos.
Old Mar 30, 2008 | 11:59 AM
GrayG35's Avatar
GrayG35
heres the dyno. the guy at the shop said i should be able to see a couple more hp if i lean it out to 13.0-13.2 just as i thought. And dam the power just drops off nasty right after peak power. i need cams!!!
Old Apr 1, 2008 | 02:13 PM
GrayG35's Avatar
GrayG35
bump
Old Apr 1, 2008 | 02:34 PM
marques1's Avatar
marques1
isn't their a uprev thread on here. You should probably post directly on there you will most likely get more responses, just and idea.
Tochigi_236
Sep 27, 2015 03:40 PM
