Newb Question about Utec and WB
Old Apr 8, 2008 | 04:13 PM
Partyboy25's Avatar
Partyboy25
Default Newb Question about Utec and WB
Probly a newb question but need to know if I need to spend some more $$$
Did a little searching and haven't found the answer to my question...closes thing was people saying to get the TXS Tuner
I am getting a Utec soon and I have a 2004.5...
... but I have read that the 2004.5 and up come with Widebands stock.
But my question is, If my car comes stock with Wideband's then will the Utec read these and log them or will I still need to get the TXS Tuner?
Sorry if this is a repost!
P.S. I did search!
Old Apr 8, 2008 | 04:26 PM
athenG's Avatar
athenG
You still need the Tuner if you are tuning it yourself of just get a standalone Wideband (Innovate, AEM..etc)
Old Apr 8, 2008 | 05:44 PM
MardiGrasMax's Avatar
MardiGrasMax
www.jeffsoftware.com
Check out the UTI software, it allows you to datalog a UTEC and wideband other than a TXS Tuner.
Old Apr 8, 2008 | 07:33 PM
JonnyC's Avatar
JonnyC
Even though your car may have wideband sensors, the UTEC doesn't tap into the computer to get these readings. Like they said above you will want to get a wideband controller and have another o2 sensor welded up in your HFCs. The AEM and LC-1 come with Bosch o2 sensors, and you can use software like MPS_logger and UTI to merge the UTEC logs with the wideband readings. Or you can spend the money to get the TXS Tuner so that you won't need any sofware to merge the two. Check out the sticky in this forum, "UTEC Upgrade", for more information on that.
Old Apr 8, 2008 | 07:52 PM
JS04's Avatar
JS04
^^Ya know everyone keeps posting the jeffsoftware link but I never see a place on where to purchase the uti software.
Old Apr 9, 2008 | 04:27 AM
athenG's Avatar
athenG
you have to pay first before you can download... click UTI and underneath there is pay button and then you'll get an email were you can logon and download the software...
Old Apr 9, 2008 | 10:39 AM
JonnyC's Avatar
JonnyC
Yeah, he needs to update his website so that the links are very clear - at least having the images link to the software page. I did the same thing the first time I went there.
Old Apr 10, 2008 | 06:41 AM
gothchick's Avatar
gothchick
Get a TXS Tuner.... My UTI lagged too much behind the UTEC to make meaningful tuning mods from the UTI logs... The UTI dashboard is really cool though.
Old Apr 10, 2008 | 07:53 AM
raditz's Avatar
raditz
You use UTI and the TUNER? how many delay you put in the configuration?
Old Apr 10, 2008 | 12:05 PM
gothchick's Avatar
gothchick
I tried to use UTI..... But for whatever reason, it wouldn't stay synched with UTEC. I'm thinking it got out of synch because UTI is polling the factory 02 sensors, which are controlled by the ECU, then tries to insert those values into the UTEC log in real time... But in my case it was always a little behind. So the AFRs would be out of synch with the rest of the log.
Now I just tune with the TXS Tuner + UTEC from the native data logs. The raw data dump isn't as pretty as UTI, but still works well.
Old Apr 10, 2008 | 01:41 PM
MardiGrasMax
Ive been using the UTEC logger for my full throttle pulls, its just as good as the UTI. The UTI AFR tables spread sheet is ver usefull for the part throttle tuning. I can manipulate the throttle to hold 2psi or 4 psi all the way up to redline and the UTI table makes it very easy to make the adjustments.
Old May 22, 2008 | 07:31 PM
Dieselinvasian's Avatar
Dieselinvasian
so whats better uti or mps logger?
Old May 24, 2008 | 03:57 PM
JonnyC's Avatar
JonnyC
I would go with UTI - cheaper, and has a bunch more features.
Old May 25, 2008 | 09:07 AM
mw9's Avatar
mw9
maybe you guys can help. I have my utec and tuner installed. I can read my AFR on the tuner and the utec works fine. My question is when I have the utec main screen up I can not see my tuner. Any suggestions, maybe something I am doing wrong. I have the tuner plug into the utec through the serial connections.
issyz
Jul 2, 2017 03:04 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
