HELP!!! utec boost controller- how to get it working?
Old May 6, 2008 | 04:52 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Originally Posted by 350zDCalb
wait, what? red is constant power, one wire i thought wasnt used, and the other goes to pin #2, please specify..thanks!
I had both my red and blue wires hooked up to the same switched 12v source. The black wire goes to pin #2
Old May 6, 2008 | 06:07 PM
QuadCam's Avatar
QuadCam
what kind of turbo setup do you have this hooked up to? internal or external wastegate? if external, are you using both ports?
all this makes a difference in how the bcs control the boost. one way, you are trying to limit the boost that goes to the actuator or side port of the gate in an effort to increase overall boost pressure...in the other setup, you are using the BCS to allow boost to go to the top port of the gate to hold it closed- allowing the turbo(s) to make more boost.
I have been running the TXS BCS for a long time now and I run in closed loop control. I am one of the few who runs closed loop, and I love it!
Old May 7, 2008 | 07:00 AM
Barzten1's Avatar
Barzten1
I have the Greddy kit. External wastegates I believe.
Old May 7, 2008 | 04:17 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
thx for the feedback... ext wastegates... can you take a screen shot of your utec settings and paste up? also, did you wire the bc as mentioned above? red and blue to switched power and black to pin#2????
Thanks
TODD
Old Aug 25, 2008 | 11:01 AM
Barzten1's Avatar
Barzten1
Hopefully gunna get this going this week. Anymore insite?
Old Sep 22, 2008 | 08:50 AM
D-tuned's Avatar
D-tuned
^ where you able to get the UTEC to control boost? what changes did you make to get it to work??
Old Sep 22, 2008 | 08:52 AM
Barzten1's Avatar
Barzten1
Yeah he got it working. think he had one of the wires backwards.
Old Sep 22, 2008 | 08:54 AM
D-tuned's Avatar
D-tuned
you know which one? or did he wire the red and blue wires together to a switched 12v source and the black wire to pin #2?
Old Sep 22, 2008 | 09:27 AM
Barzten1's Avatar
Barzten1
Man I wasnt there when he did it but I think he ended up calling TurboXS and they helped him out.
2ndchanceZ
Oct 26, 2015 08:03 PM
_bit
Oct 2, 2015 07:49 AM
