MRC makes MORE POWER !! 284whp N/A
Old Jul 17, 2008 | 06:37 PM
13SECZ's Avatar
13SECZ
She runs pretty good...we were able to consistently get around there..283, 284, 285 on one pull...I believe we were runnin around 26 degrees of timing max in the higher rpm's....don't quote me though...I'd love to get to a track but its so far away and so damn hot out lately...plus I sold my stockers and I really don't wanna burn up my rear 19's....
Old Jul 17, 2008 | 10:21 PM
KA24DE's Avatar
KA24DE
Originally Posted by 13SECZ
Im not sure it would make me faster overall..i put down about 30 more lbs of tq then most z's with bolt ons that are rev up or hr....Now the higher redline pwer would help..but not sure it would make me faster down the quarter....
Yes, you would be. You'd have access to more power, and each shift at your extended redline would land you deeper in your powerband.
Old Jul 19, 2008 | 12:09 AM
13SECZ's Avatar
13SECZ
not a bad idea..but at this point...I will leave it till I possibly go f.i....but prolly not.
Old Jul 19, 2008 | 06:11 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
good #'s man!
Old Jul 19, 2008 | 02:44 PM
13SECZ's Avatar
13SECZ
its no 300+ like you..but it works...it takes out some of the cars that think they should win..based on internet races..lol
Old Jul 21, 2008 | 09:17 AM
jbudnick504's Avatar
jbudnick504
Thats one fast NA z
Old Jul 21, 2008 | 06:49 PM
13SECZ's Avatar
13SECZ
thanks man...especially when its not 90 degrees....I hate heat..
Old Jul 22, 2008 | 04:01 PM
BakaN20's Avatar
BakaN20
Its not that much of a sacrifice with the mrev2 and spacer. I lost about 1hp at peak for like, 200 rpms and it level out to where my original revup peak was, but i gained crazy tq and hp in the midrange, so putting a revup lower plenum would not benefit you.
Old Jul 23, 2008 | 09:05 PM
13SECZ's Avatar
13SECZ
besides the utec and test pipes we have the same mods..
Old Jul 24, 2008 | 02:47 PM
FAIRLADYZ_MANnE's Avatar
FAIRLADYZ_MANnE
however with cams and rev up manifold. i would like to see those numbers top end wise.
KA makes a good point. is there anyone with that set up?
Old Jul 29, 2008 | 11:41 PM
VQdriver's Avatar
VQdriver
do you feel like there's more to be gained from a true dual exhaust? i am so torn between a cheaper frankenstein pieced single exhaust setup and a nice true dual. does an NA setup really need true dual? i see that even the top dollar NA builds here don't necessarily have duals.
Old Jul 31, 2008 | 11:51 AM
tylerxfire's Avatar
tylerxfire
is utec the way to go for the z?
Old Jul 31, 2008 | 01:41 PM
BakaN20's Avatar
BakaN20
Pretty much. Its cheap compared to others, and it works for everything a Z needs. If you are on the east coast, then you are good, because I don't think there is a cobb tuner or uprev tuner on the east.
I would like to use the Osiris from UpRev though, it seems really good. Now if Julian was an Osiris tuner, then I know what I would do for an ems.
Old Aug 1, 2008 | 04:58 AM
VQdriver's Avatar
VQdriver
hey guys, what about a reflashed ECU tuned on a dyno? cheaper still...i'm not sure how effective it is for an all motor setup.
Old Aug 1, 2008 | 06:36 AM
Diesel350's Avatar
Diesel350
So did you ever get a base line dyno?
Old Aug 6, 2008 | 12:22 PM
Subninja's Avatar
Subninja
Default shop
Was the shop in CT called SWIFT Motorsports?
Old Aug 6, 2008 | 03:42 PM
13SECZ's Avatar
13SECZ
No it wasn't swift....I did get a base line dyno...here's how it kind of worked.
Diff dyno: 251 whp stock then 267 whp modded...then that 267 tune is what I went in at mrc with....and came out with the curve u see...because it was a diff dyno the number to me doesn't mean so much , u can however see the diff in the hp curve...
Old Aug 6, 2008 | 03:48 PM
  #38
doug's Avatar
doug
bouncing around from shop to shop.. sounds like 'the shop' in norwalk
Old Aug 6, 2008 | 09:56 PM
  #39
13SECZ's Avatar
13SECZ
I did most of the installs myself...the tuner bounced around....I think he still does...so "the shop" or any other shop named here is not to blame...and truthfully the car ran good before...but there was more left in it..
thats kind of my point...
better tuner = more power...
Old Aug 7, 2008 | 08:19 AM
  #40
doug's Avatar
doug
i have a feeling who the tuner is.. lol
sales@czp
Sep 23, 2019 03:30 PM
