What settings to use on Cipher for a TEST RUN
Old Aug 27, 2008 | 09:04 PM
civic4982's Avatar
civic4982
Default What settings to use on Cipher for a TEST RUN
So I'm getting the vortech supercharger full kit for the revup installed on Friday/Saturday.
I also just recently purchased a Osiris/Cipher cable and Rich from Uprev was kind enough to send me the newest version of the software.
My question is this:
I'm going to be logging data to analyze this run to see if tuning will be necessary (if it runs too lean though I'm using stock cats and simply nismo headers/exhaust so it shouldn't be a problem according to Vortech).
What values do you all think I should definitely have logging and pay attention to?
Should I simply use the "Performance Logging" button and have it run all those values?
Mine is an '05 G35 Coupe so it comes with wideband readings. My plans is to have the following recording for analysis:
A/F Wideband Sensor B1
A/F Wideband Sensor B2
Ignition Timing Advance
Mass Air Flow gm/s
Mass Air Flow volts
Throttle Position Sensor 1
Throttle Position Sensor 2
Engine Speed
Vehicle Speed
Are there any others you all would suggest?
Is there a way to measure in percentage the duty cycle of my injectors or their flow rate?
Thanks.
Old Aug 27, 2008 | 09:10 PM
rookie's Avatar
rookie
battery voltage
injector pulse width b1
injector pulse width b2
intake camshaft adv b1
intake camshaft adv b2
intake air temp
water temp
if you're an auto do turbine revolution
Old Aug 27, 2008 | 09:19 PM
civic4982's Avatar
civic4982
I'm a 6MT...
thanks!
what does injector pulse and intake camshaft advance tell me and what values are "normal"
I may do a test run with all these values first before the install and then compare it to after the install to see what issues have changed.
Old Aug 28, 2008 | 08:39 PM
civic4982's Avatar
civic4982
bump anyone else have any tips?
Old Sep 4, 2008 | 05:14 AM
gothchick's Avatar
gothchick
Rookie was just messing with you (I hope).
Try these for 'normal' logging, or ask your tuner what he suggests:
AFR WB-B1 (AFR)
AFR WB-B2 (AFR)
B-FUEL SCHDL (ms)
IGN TIMING (BTDC)
CAL/LD VALUE (%)
ENGINE RPM (rpm)
THROTTLE POS 1 (V-Throttle)
COOLANT TEMP (C)
ENG OIL TEMP (C)
INTAKE AIR TMP (F)
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
codek
Sep 28, 2015 03:03 AM
