Just Had ECU Reflashed Again For Cams
Although I have had Nismo cams in my car for more than a year I hadn't had my car's ECU reflashed to account for them until this week. So far it seems to be running much better after the reflash.
Background: I had my ECU reflashed by Technosquare a couple of years ago after my last bolt on mod. Then about a year later I decided to install Nismo cams. After the cam install my car ran a little rough at idle so my local dealer bumped the idle to 900 rpm. After that the car ran fine for about six months until I started getting random check engine lights for a cylinder misfire. Then about a month ago at a autocross event my check engine light came on several times with a P0300 code (misfire).
Each time I reset my check engine light with my Scanguage it came back on while I was at the autocross. Since the autocross the check engine light hasn't come back on. However, a new local tune shop was having a grand opening last Saturday where you could get two dyno pulls on a dynojet with A/F readings for $40 so I decided to have my car dynoed. Not only did the car not make the horsepower I was expecting given my mods (260 rwhp) it was running very lean under 3,500 rpm and still lean up to about 5,500 rpm. Based on the dyno results I decided I needed to have the ECU reflashed again. Note: Once Technosquare reflashes your computer the first time they will reflash it again for $150.
Now I need to see if I can get it dynoed again for comparison sake. I will post my results once I have it dynoed again.
I finally got a chance this morning to get out and really drive the car. I'm sure the cool weather this morning didn't hurt, but the car feels like a entirely different car. It really pulls hard now from idle all the way to redline. More to come when I get my new dyno results.
