MPS Logger + AEM WB Issue
Old Nov 10, 2008 | 10:36 AM
carlos305's Avatar
carlos305
Default MPS Logger + AEM WB Issue
ok so i installed my AEM WB and my UTEC then i connected both to my laptop with a cheap usb-to- serial cable from a local computer store and everything was working perfectly fine. the next day i plug everything back in and my laptop wouldnt detect my aem connection so played around with the drivers but nothing seemed to work... So i went to radioshack and bought a $37 usb to serial cable and now MPS detects the AEM WB and it shows the AFR on the laptop for a moment and then it just freezes and wont show it anymore. I know its not the cable because i can see my afr when i use the AEM setting on Hyper Terminal and that works perfectly fine. I have tried to fix this for a week now and its really frustrating me. Anyone have any ideas on what might be wrong?
BTW: I'm using Vista and the RadioShack USB-to- Serial Cable
Old Nov 10, 2008 | 10:52 AM
athenG's Avatar
athenG
Are you sure MPS is compatible with Vista?
Old Nov 10, 2008 | 11:19 AM
carlos305's Avatar
carlos305
im guessing it is because everything worked fine for a day and i even tried installing xp but i got the same problem
Old Nov 11, 2008 | 10:51 AM
carlos305's Avatar
carlos305
those who are using the AEM WB what brand usb-to-serial converter are you guys using?
Old Nov 11, 2008 | 08:40 PM
str8dum1's Avatar
str8dum1
after tryin 3 or 4 serial->usb with the AEM, none of them worked and always froze/blue screen of death. running serial into the computer has been 100% working.
Old Nov 12, 2008 | 11:28 AM
carlos305's Avatar
carlos305
can you explain what you mean by "running serial into the computer has been 100% working." ? thanks
Old Nov 12, 2008 | 11:56 AM
str8dum1's Avatar
str8dum1
i use the serial cable off the AEM with no convertor and it has worked 100% of the time. I use the usb off the UTEC.
if you dont have a serial connection at all on your computer, cant offer any further advice because none of the usb convertors i tried worked more than 50% of the time.
Old Nov 15, 2008 | 05:07 PM
carlos305's Avatar
carlos305
After two freaking weeks of breaking my head installing/uninstalling every windows/driver possible i decided to go back and check all the wiring and i found my problem... This whole time the problem was a bad ground! At least that gave me some time to re read the utec manual several times and now i think i'm reading to do some tuning
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
