Weird issues with my UTEC...pls help !
Old Mar 2, 2009 | 01:39 AM
zerosec's Avatar
zerosec
^ yeah ur right about the base map but i said if someone shares his map it might bi a bit better than the one i have right now...
anywayz one more question, you tune using 4th or 5th since there's more load on the engine ? you have the same A/F for all gears ?
Old Mar 2, 2009 | 02:11 AM
zerosec's Avatar
zerosec
Old Mar 2, 2009 | 06:31 AM
frankie945's Avatar
frankie945
When road tuning use 4th and if u dont have enough room then use 3rd. Also it is best if u can find a long strech of road uphill.
Old Mar 2, 2009 | 06:38 AM
athenG's Avatar
athenG
If you have a dyno then 4th or 5th is good gear to tune but for street tuning I tune most of the time at 3rd and 4th gear. I use 3rd and 4th because there are not a lot of space in NYC where I can run 130mph just to tune my higher rpm so I use my 3rd gear to tune above 6000rpm. Turbo rely heavily on load so every gear will have different load but on my car I run a little leaner on lower gears and I run the richest on 5th gear but not a huge difference though, I would say I may see 11.7 A/F on 3rd at 8psi@6000rpm and 11.4 A/F on 5th gear at 8psi@6000rpm. Not sure if this is the case on NA but this is just how my car react... lol
Old Mar 2, 2009 | 02:10 PM
zerosec's Avatar
zerosec
^ aha i guess these A/F numbers are without water injection, right ??
Old Mar 2, 2009 | 02:28 PM
athenG's Avatar
athenG
That is with W/M and with 2-3 deg more timing, without meth I would target 11.3-11.5 on 93 octane.
Old Mar 2, 2009 | 03:01 PM
zerosec's Avatar
zerosec
why not go for leaner mixture to maximize the potential of WI...???
Old Mar 2, 2009 | 04:56 PM
athenG's Avatar
athenG
Dont want to take a risk coz what if the kit fail? Even with the atomization of Meth/water there is still a risk of uneven distribution of meth on each cylinder, I know the risk is not as high with NA coz the turbo create turbulence to keep the water/meth atomized even after passing a dry manifold. I'm still on stock block so basically I went with a water/meth injection to give an added safety and not to squeeze all the power I can muster.
Once I'm ready to build the motor or have the fund for a built motor then this baby will see 2-3 more psi and leaner AF but I dont see that anytime soon.. lol
Old Mar 9, 2009 | 12:41 PM
zerosec's Avatar
zerosec
2-3 PSI are going to cost you lots of money haha :P
Old Mar 16, 2009 | 02:59 PM
zerosec's Avatar
zerosec
do u need to adjust the fuel trims when u go with bigger injectors ? ;/
Old Mar 17, 2009 | 06:17 AM
athenG's Avatar
athenG
Yes, you will need to re-tune the entire fuel map with bigger injectors.
Old Mar 17, 2009 | 06:06 PM
zerosec's Avatar
zerosec
^ so i need a scanning tool right ?
Uriyo_
Sep 8, 2021 08:46 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
