ECU Pinout for 06
Old Feb 5, 2009 | 03:27 PM
carlos305's Avatar
carlos305
Default ECU Pinout for 06
Is the ecu pinout for 06 same as 03-05? is pin 62 still rpm signal on the 06?
Old Feb 5, 2009 | 03:30 PM
cdoxp800's Avatar
cdoxp800
http://www.innovatemotorsports.com/r...5_G35_350z.php
Old Feb 5, 2009 | 03:34 PM
carlos305's Avatar
carlos305
so i guess that includeds 06's?
Old Feb 5, 2009 | 03:44 PM
cdoxp800's Avatar
cdoxp800
Originally Posted by carlos305
so i guess that includes 06's?
From my reading yes
carlos305's Avatar
carlos305
is their an easier way of getting rpm signal without going through the ecu?
Old Feb 5, 2009 | 03:46 PM
cdoxp800's Avatar
cdoxp800
What are you wanting it for?
Old Feb 5, 2009 | 03:49 PM
carlos305's Avatar
carlos305
i need my car to blow up at 4000 rpms lol jk window switch...
Old Feb 5, 2009 | 03:51 PM
cdoxp800's Avatar
cdoxp800
Window Switch ??
Old Feb 5, 2009 | 03:52 PM
carlos305's Avatar
carlos305
Window Switch ??
rpm window switch for nitrous...
Old Feb 5, 2009 | 03:55 PM
cdoxp800's Avatar
cdoxp800
Well then I would just go to the ECU then.. It's not that hard to get to
Old Feb 5, 2009 | 04:05 PM
carlos305's Avatar
carlos305
yea but those damn ecu cables are so skinny im scared of breaking them lol, thats why i wanted to see if their was another way...
Old Feb 6, 2009 | 06:14 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Pin 62 has not changed between the 03-06 years. Also it is ignition output #1, and you could also get it at the ignition coil if you wanted.
Old Feb 6, 2009 | 08:22 AM
mw9's Avatar
mw9
Has anyone heard about putting a meter on that pin and setting it to hertz and able to tell you RPM's. I am looking a small shift light and their website says if you can do this, then that pin will work with their unit?
Old Feb 8, 2009 | 08:12 AM
rzua5's Avatar
rzua5
I was looking into that as well for my 35anni Z but I think 05 Revup and 06+ had a different ecu layout than the 02-04. It is no longer pin 62. I am having a hard time locating a tach signal for my VSD-X. Hopefully someone can chime in..
Old Mar 2, 2009 | 06:43 PM
ashtrojan2008's Avatar
ashtrojan2008
for the 06 rev up, pins are the same, wire colors are different. If you need the colors you can convert them using the 06 factory service manual.
Old Mar 2, 2009 | 06:44 PM
ashtrojan2008
i'm sure for a tach signal you need to use a coverter like the one used with the greddy emanage.
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
