ECU
Old Mar 4, 2009 | 07:33 PM
PhilliamWallace's Avatar
PhilliamWallace
Default ECU
When I replace my stock air system with dual pop chargers from JWT. Do I have to reprogam the ECU? I need some feedback! Thanx
Philliam
Old Mar 4, 2009 | 08:10 PM
You better unless you want to explode in a ball of flames!
Old Mar 4, 2009 | 08:36 PM
melloyello370's Avatar
melloyello370
You need not do anything if you don't want to. You may still experience some gains but not likely as much as you would with a re-flash but then what's the point unless you are going to add a few more items.
And no, you will not explode into a ball of flames. lol
Old Mar 4, 2009 | 08:37 PM
MGibson24's Avatar
MGibson24
Im sure many others can answer this better than I but I just installed a single pop on my rev-up like 6 hours ago and read that you should disconnect the negative before installing. This will cause the MAF to re-read when reconnected and prevent (hopefully) the stalling issue people are reporting. I don't think anything else is necessary.
Old Mar 4, 2009 | 08:41 PM
Good idea. Anytime you mess with any type of sensor (MAF) disconnect the battery.
Old Mar 4, 2009 | 10:38 PM
maXmood's Avatar
maXmood
Under Boost!
a normal ecu reset will do.. search for the procedure (should be really easy to do).
Old Mar 5, 2009 | 09:34 AM
UpRev's Avatar
UpRev
Yes, 100% ball of flames.
Oh wait this isn't the FI forum.
You do not need to get your ECU reprogrammed for any modification. Will it help? yes. But then a good tune helps even on completely factory cars. If you're located near one of our Pro Tuners, http://www.uprev.com/dealers.php You can stop by and talk to them and they can give you plenty of details about it.
Old Mar 5, 2009 | 02:36 PM
CSF's Avatar
CSF
Philliam
if by reprogram the ECU, you mean reset it...then yes. You don't have to reset it as the ECU will eventually learn, but it is a good idea.
if you meant reflashing your ECU, then no.
Old Mar 6, 2009 | 09:18 AM
__jb's Avatar
__jb
Z + Rear Seat
When your ECU "Learns" your new mods, it is actually adjusting itself (its internal tables) so that your new mods run within the emissions parameters the ECU was designed to produce. That's never the best for performance.
Having your ECU reprogrammed (flashed) with something like Osiris on a dyno by a real Tuner makes quite a difference. Now your ECU "Learns" towards the performance settings the Tuner flashed onto the ECU.
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
