My Haltech tuning adventure
Old Oct 9, 2009 | 04:03 PM
OldManZ350's Avatar
OldManZ350
Hi Jon,
I hope it's going well with your tuning.....
I got your Message on my answering Machine to talk about your Tuning.
As far as the HalTech is concerned, you are talking to the Expert.
" HAL is the MAN".
If you have questions concerning your Vortech or general Tuning question, I'd be glad to talk with you.
Tim
Old Oct 10, 2009 | 10:48 AM
sajazzman007's Avatar
sajazzman007
DIY'er Unite
Originally Posted by OldManZ350
Hi Jon,
" HAL is the MAN".
Tim
Thanks Tim
Old Oct 12, 2009 | 11:14 AM
sajazzman007
DIY'er Unite
Been working on trying to get the car to idle with Hal and others. Trying to figure out how to datalog the car as I'm working on the map? DOes anyone know how to do that? The manual says nothing about it.
Old Oct 12, 2009 | 11:24 AM
binder's Avatar
binder
Originally Posted by Chris@FsP
Be careful man. There is very little room for error when tuning a forced inducted vehicle.
there is tons of room for error tuning any car as long as you are on the rich side of the tune and you keep the timing pulled back to normal values.
hopefully i should have my haltech by the winter. subscribed for the results!
Old Oct 12, 2009 | 11:38 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
The problem is... what are normal values? If you are too "conservative" on timing you can easily do damage as well via increased temperatures.
Old Oct 12, 2009 | 11:40 AM
Dynosty's Avatar
Dynosty
PM sent.
Old Oct 12, 2009 | 08:29 PM
sajazzman007
DIY'er Unite
Thanks for the encouragement. As I continue on my adventure I'll keep everyone posted. I have been working with Hal and GMX on getting the map together. It's slowly comming along.
Old Oct 13, 2009 | 08:25 AM
binder's Avatar
binder
ah, point taken.
normal is what the stock ems decides log those then keep them around that much. good to go. lol.
Old Oct 13, 2009 | 05:57 PM
Chris@FsP's Avatar
Chris@FsP
ah, point taken.
Really? Stock ecu timing values for FI?
Old Oct 13, 2009 | 06:09 PM
binder's Avatar
binder
mine is 0 adjustment until around 5psi at higher rpm (i'd have to check what my map is set at).
stock ecu should pull timing when it detects knock so it's pretty conservative. just keep the timing pulled under that knock threshold and you're good. So far i've logged zero knock on my car since i've installed my vortech. 12psi.
Old Oct 19, 2009 | 08:46 AM
rcdash's Avatar
rcdash
It should but it doesn't, at high rpms, which is where you reach max boost. Very dangerous for a SC. Don't think the stock ECU will save you. If you've got a UTEC, you may be ok if you're knock thresholds are dialed in, but that's living life on the edge. 5 psi is not 0 psi - the timing maps should not be the same.
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
