Timing help
Old May 8, 2010 | 06:46 AM
GT-2 350Z's Avatar
GT-2 350Z
Default Timing help
I am looking for help to get my timing set. I run a trigger wheel off of my crank pulley through a motec ecu and we are only getting an intermittent spark when cranking. In the off season I moved the crank sensor to a better position and I think that I may be off so that the crank wave and cam wave are not in sync and causing the intermittent spark. So what I need is if someone has a revup out and can tell me which tooth the crank sensor is on at top dead center or take a picture of it.
Thanks for any help you can give.
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
