Osiris: ROM Editor - License error!
Old May 15, 2010 | 12:25 PM
maXmood's Avatar
maXmood
Under Boost!
Default Osiris: ROM Editor - License error!
i've upgraded my Osiris from standard to tuner version and it worked fine.. i used to hook up the cable and view the tables/figures in the e-tune Uprev sent me.. now after couple of weeks of not touching it, i'm trying it again but it give me (License error!) every time i try to load the rom file!
after couple of attempt, i thought maybe i need to update the software, and i used the updater, but nothing changed.
any ideas?
Old May 15, 2010 | 12:43 PM
cdoxp800's Avatar
cdoxp800
any ideas?
What is the Error you are getting?
Did you update your Cable license for the Turner Version?
What cable Firmware you running?
I have to run for a bit, but I will be back later. I have an idea what it may be.
Old May 15, 2010 | 12:45 PM
maXmood's Avatar
maXmood
Under Boost!
1- error says: License error!
2- yes i did and it used to work just fine.
3- firmware 1.71 (0x0171)
Old May 15, 2010 | 12:50 PM
cdoxp800's Avatar
cdoxp800
Ok try this:
In order to get the latest firmware (1.75) you need to download this file.
http://uprev.com/updates/Osiris%20Tuner%20Installer.exe
For some reason the firmware is not coming down with the update tool. After you install this run the updater again and then try to update your cable.
Now last night I got this error when using the Osiris Flash tool. I have emailed Jared about it.
Attached Thumbnails Osiris: ROM Editor - License error!-untitled1.png
Old May 15, 2010 | 01:02 PM
maXmood's Avatar
maXmood
Under Boost!
Ok try this:
thanks for that.. but i figured it out...
i've installed the same version i'm running and it worked fine. after running the ROM Editor, you should get the message: "Definitions loaded Ok", and that's what didn't get in the previous installed app.
anyways, i'm downloading the file from the link provided, that should be even better..
now, on to your issue..
tbh, Uprev sucks @ customer service, and you got alot of resellers that can help/serve you better.
do you have the tuner version? or just standard?
did you rename the flash file by any chance?
Old May 15, 2010 | 02:47 PM
cdoxp800's Avatar
cdoxp800
I have the Tuner Ver. I found away around using Osiris to do the Flash. I used the Rom editor to flash my car.
And yes I did rename the File.
Old May 15, 2010 | 03:12 PM
maXmood's Avatar
maXmood
Under Boost!
ok.. i know it shouldn't have to do anything with renaming the file, except if you renamed the extension (which i doubt it, because you won't be able to open it with the editor).
try to do what i did and reinstall the software. if you did that already, then move the file Osiris.exe and its DLL files to some other folder, and then run the Updater to try and get a newer version.
hope that works..
Old May 15, 2010 | 03:13 PM
cdoxp800's Avatar
cdoxp800
hope that works..
It's all good. Thanks.
Old May 15, 2010 | 03:15 PM
maXmood's Avatar
maXmood
Under Boost!
glad it is..
Old May 22, 2010 | 12:17 PM
maXmood's Avatar
maXmood
Under Boost!
another problem now!!
just came up today when i was trying to run any of the apps (ROM Editor, Updater, Osiris, Cipher)..!if i continue, i can't use the application properly. stuck or doesn't load the maps.
i tried to uninstall it/reinstall it, nothing... i re-downloaded it again and installed it, to no avail..
Old May 22, 2010 | 02:00 PM
SmallTuner's Avatar
SmallTuner
just download microsoft net framework 3.5 alone and then after that, install the Osiris installer
hope it will work
Old May 22, 2010 | 11:23 PM
maXmood's Avatar
maXmood
Under Boost!
hope it will work
i have it installed already..
i'll reinstall the framework and see how it goes.
thanks
Old May 23, 2010 | 02:07 AM
maXmood's Avatar
maXmood
Under Boost!
re-installed the framework and got rid of this message. but unfortunately, i got the previous problem again!i removed the whole thing and reinstalled it, still the same problem.. i don't know why i'm having so much problems with this.
Old May 23, 2010 | 02:23 PM
SmallTuner's Avatar
SmallTuner
did u dowload microsoft Framework 3.5 ? sould e 3.5 or higher.
Old May 23, 2010 | 08:44 PM
maXmood's Avatar
maXmood
Under Boost!
yes.. it's installed already.
this problem doesn't have to do with MS Framework.. it has to do with the ROM Editor itself.
last time i had the same problem, and all i did was uninstall/reinstall and it started working fine, because as it seems, the ROM Editor isn't reading definitions.. i don't know why!?
Old May 25, 2010 | 01:06 AM
maXmood's Avatar
maXmood
Under Boost!
totally forgot i have to connect the cable to be able to run the ROM Editor..
DUH!
All working good now..!
Old May 26, 2010 | 06:11 PM
cdoxp800's Avatar
cdoxp800
Old May 26, 2010 | 10:19 PM
maXmood's Avatar
maXmood
Under Boost!
i like your siggy quote.
aarrgghh
May 1, 2022 11:04 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
