gear swap (which breaks CC) and osiris
Old Jun 15, 2010 | 11:01 AM
Entaille's Avatar
Entaille
Default gear swap (which breaks CC) and osiris
I'll be swapping gears with someone soon. It is going to break CC functionality - anyone experience this while having Osiris? are you still able to change maps?
I'll contact UpRev if I need to, but I figure someone here has osiris and different gears.
Old Jun 15, 2010 | 12:08 PM
Entaille's Avatar
Entaille
cc being cruise control.
Old Jun 15, 2010 | 12:22 PM
gabe3d's Avatar
gabe3d
I went from stock to 4.08 gears and my CC still works as well as my map switching in Osiris.
Old Jun 15, 2010 | 12:23 PM
Entaille's Avatar
Entaille
really? I am reading about all sorts of folks having their cruise control functionality busted when they change gears. I'm not even going that extreme, just 3.3 to 3.5.
Old Jun 15, 2010 | 12:24 PM
- bigc -'s Avatar
- bigc -
hey gabe, did u swap the gears yourself or did you have a shop do it? i'm thinking of going up to 3.5s in the near future.
Old Jun 15, 2010 | 12:34 PM
Entaille's Avatar
Entaille
if I was paying for the swap (as a 5at owner) I would be aiming for 3.7s or maybe 3.9s, personally.
the 3.5 swap is free so I am jumping on it.
just having a local swap our pumpkins. did you have to do anything special to maintain cruise control functionality?
anyone run into this issue? if mine breaks, I am curious if Osiris will still let me change maps.
Old Jun 15, 2010 | 12:36 PM
gabe3d's Avatar
gabe3d
Yes really, not sure if it matters but I have a MT and mine is a G35.
Beshoff did it for me at the same time when I installed the Quaife LSD. I think if you do gears you might as well do LSD and save yourself 400-500 install
Old Jun 15, 2010 | 12:44 PM
- bigc -'s Avatar
- bigc -
thanks for the info gabe. what's your impression of the quaife LSD? i don't want to sacrifice too much ride quality or hear any clicking from the rear end (a friend of mine with the nismo LSD clicks like a ****).
as for 3.7s, i'd love to go that far, but i already have traction issues with the vortech.
anyway, good to know the map switching capability won't be lost with gear swaps
Old Jun 15, 2010 | 12:49 PM
gabe3d's Avatar
gabe3d
Dead silent! It's a mechanical gear LSD as oppose to the clutch type like the Nismo. The quaife was a major step up from the stock VLSD, it'll definitely help on your traction.
Old Jun 15, 2010 | 01:38 PM
Entaille's Avatar
Entaille
ah , didn't realize you were sc'ed, big.
not to get too far off topic though, still want to hear from someone that lost cc functionality after a gear swap, while also having osiris. gotta be someone out there. : P
Old Jun 15, 2010 | 01:59 PM
hellsoldiers08's Avatar
hellsoldiers08
I thought stock gearing was 3.53?????
Old Jun 15, 2010 | 02:00 PM
Entaille's Avatar
Entaille
it is, for MT. AT's come with 3.3s - swapping pumpkins with a G35 6mt.
Old Jun 15, 2010 | 02:25 PM
hellsoldiers08
O, learn something new every day. also thought cersuies control was done by ecu and not machincal?
Old Jun 15, 2010 | 02:44 PM
Entaille's Avatar
Entaille
"The cruise control, if I'm not mistaken, takes it's reading form the transmission output shaft...and now that the speed vs. rotational RPM's have changed - it fubars....none that I know of YET to fix this...but working and researching it out thoroughly."
this was in 2005.. from a thread on g35driver. another member talked to TS and found that there is no ecu setting to resolve this.
kind of sucks. I haven't found a single resource with a solution. I think Osiris will still work, if no one's encountered this scenario, I'll post my findings after the swap.
Old Jun 15, 2010 | 03:06 PM
hellsoldiers08
Ya, i would contact uprev. This is a first that i have heard of this, and to top it off i was thinking about doing the gear change in the next year but after hearing about this idk (that if the problem still happening for the 07 yr model). Well i say just take a risk and how often do you really use cruise control :/
Old Jun 15, 2010 | 03:10 PM
TheFarmer's Avatar
TheFarmer
Entaille, we have 4.08 gears in my brother's Z and his cruise control still works fine.
spnall4's Avatar
spnall4
Y so SrS!
I went from a 3.5 to 3.9 gears and my cc works just as before as well as map switching. I'm also tuned via osiris.
Old Jun 15, 2010 | 04:39 PM
- bigc -'s Avatar
- bigc -
i wonder if there is some slight difference between model years and/or 5AT vs 6MT that causes some folks to lose cruise control while others are fine.
Old Jun 15, 2010 | 08:58 PM
Entaille's Avatar
Entaille
it is sounding like it. it's too bad we dont have a compilation of years, trims, and tranny types that experienced CC messing up.
honestly, I never use CC, I just want to keep the map swapping ability : P
Old Jun 15, 2010 | 10:38 PM
midz350's Avatar
midz350
I think people lost there cc when they went from 3.53 to 3.35 and only in 5th and 6th gears.
