UTEC or ECU retarding timing
Old Nov 6, 2010 | 02:47 PM
12AutoX's Avatar
12AutoX
Default UTEC or ECU retarding timing
Regardless of tuning in open loop or closed loop, I am having this problem. I will set timing numbers in certain cells, esp. 80% and 90% load, between 6000 and 6500 rpm at 22 btdc. The ECU reads 26 (what it would have chosen), and the modified (what I supposedly chose) reads 18. How is it that I can tell the computer to run 22 and only get 18? The knock count is 00 when this is happening most of the time. It looks like throughout the mid to upper rpm ranges the timing varies a lot from what I told it to use, from .5 up to about 6 degrees. Sometimes it's worse than others. Does the ECU ignore my requests in order to protect the engine? Is this a "feature"?
Old Nov 11, 2010 | 10:57 AM
athenG's Avatar
athenG
Post some logs so we can see more of the data. On close loop the ECU has full control so your own timing map will not be used. we need to see what parameters you have. Check your Temp Compensation table to make sure it is not pulling timing when temp changes. Are you running speed density?
Old Nov 12, 2010 | 06:28 PM
12AutoX's Avatar
12AutoX
I'm running MAF pull down (N/A), not speed density. The temp compensation hasn't been set, so there should be no variance. This first log is from early in the run. The second one is from a litle while later (like a few minutes later). Notice how the timing gets pulled from the first run to the second.
rpm__________TPS_Load_Knock_ECU IGN__MOD IGN_______AFR
3245 -17.9 3.52 95 60 00 14.79 +24.2 40.5 +28.5 +4.7 3.70 13.59
3313 -17.9 3.50 96 70 00 13.00 +24.3 35.7 +28.2 +4.6 3.64 13.23
3343 -17.9 3.49 97 70 00 13.03 +25.3 36.3 +27.9 +4.5 3.70 13.17
3401 -17.9 3.56 99 70 00 13.14 +24.2 37.6 +27.9 +4.4 3.74 13.39
3447 -17.8 3.60 99 70 00 13.71 +24.1 37.6 +27.8 +4.3 3.76 13.50
3519 -17.9 3.60 99 70 00 13.85 +24.2 40.6 +27.7 +4.1 3.76 13.62
3546 -17.8 3.64 100 70 00 13.92 +24.3 41.4 +27.5 +3.9 3.74 13.59
3595 -17.9 3.72 99 70 00 13.73 +23.2 41.4 +27.4 +3.8 3.80 13.53
3639 -17.9 3.70 99 70 00 13.53 +23.2 41.3 +27.3 +3.5 3.76 13.50
3716 -17.8 3.66 100 70 00 13.34 +24.2 41.5 +27.3 +3.4 3.86 13.47
3753 -17.8 3.78 99 70 00 13.28 +23.1 41.0 +27.2 +3.1 3.76 13.39
3809 -17.8 3.78 100 70 00 12.15 +23.1 38.7 +25.8 +0.6 3.66 13.31
3858 -17.8 3.76 100 80 00 12.39 +24.2 40.0 +24.5 +0.5 3.76 13.28
3926 -17.8 3.70 100 80 00 12.25 +25.1 39.9 +23.9 +0.0 3.74 13.39
4016 -17.9 3.82 100 80 00 12.34 +24.1 40.9 +23.1 -0.2 3.78 13.59
4020 -17.8 3.86 100 80 00 12.45 +24.0 42.0 +22.1 -0.7 3.78 13.84
4055 -17.8 3.80 100 80 00 12.68 +24.1 42.9 +22.0 -0.8 3.78 14.08
4140 -17.8 3.82 100 80 00 12.57 +23.0 43.2 +22.2 -1.2 3.76 14.15
4187 -17.8 3.82 99 80 00 12.36 +23.1 43.0 +22.0 -1.3 3.72 14.15
4224 -17.8 3.94 100 80 00 12.29 +23.0 42.9 +21.8 -1.5 3.82 14.08
4278 -17.8 3.86 100 80 00 12.09 +22.0 43.3 +21.6 -0.8 3.74 14.05
4357 -17.8 3.88 100 80 00 12.38 +21.0 45.3 +21.1 -0.8 3.98 14.00
4391 -17.8 3.86 100 80 00 12.87 +21.0 47.1 +20.7 +1.4 3.96 13.84
4432 -17.8 3.94 100 80 00 13.16 +19.7 48.5 +20.4 +1.4 3.92 13.72
4498 -17.8 3.98 100 80 00 13.74 +19.5 52.7 +20.2 +0.1 4.09 13.47
4528 -17.8 3.88 99 80 00 13.83 +21.1 52.3 +20.1 +2.2 4.05 13.17
4761 -17.8 3.90 100 80 00 13.64 +21.0 52.1 +20.5 +1.9 4.01 12.86
4636 -17.8 3.96 100 80 00 13.48 +20.9 52.1 +20.8 +1.3 3.96 12.67
4681 -17.8 4.00 99 80 00 13.35 +20.9 52.1 +21.1 +0.7 3.96 12.56
4728 -17.8 4.07 100 80 00 13.53 +19.5 53.5 +21.5 -0.4 4.01 12.56
4782 -17.8 4.00 100 80 00 13.37 +22.0 53.7 +21.4 -0.4 4.00 12.61
4852 -17.8 4.00 100 80 00 13.21 +22.9 53.5 +21.0 -1.5 4.03 12.61
4859 -17.8 4.05 100 80 00 12.70 +23.0 51.4 +20.9 -1.5 3.98 12.53
4945 -17.8 4.11 100 80 00 12.93 +22.0 53.3 +20.4 -2.2 3.98 12.56
4975 -17.8 4.11 100 80 00 12.38 +22.0 51.5 +20.3 -2.5 3.88 12.61
5042 -17.8 4.07 100 80 00 12.38 +22.8 52.0 +20.1 -3.0 3.88 12.74
5081 -17.8 4.09 100 80 00 12.70 +22.9 53.7 +20.5 -3.2 3.96 12.86
5144 -17.8 4.01 100 80 00 12.59 +21.9 53.8 +20.8 -3.6 3.98 12.89
5184 -17.8 4.17 100 80 00 12.48 +23.9 54.0 +21.3 -3.7 3.96 12.92
5241 -17.8 4.15 100 80 00 12.30 +22.9 53.8 +21.5 -4.0 3.96 12.93
5299 -17.8 4.09 100 80 00 12.48 +22.9 53.9 +21.1 -4.2 4.00 12.92
5341 -17.8 4.15 100 80 00 12.55 +23.8 55.7 +21.1 -4.1 3.90 12.99
5376 -17.8 4.13 100 80 00 12.45 +24.0 65.0 +20.5 -3.7 4.03 12.93
5428 -17.8 4.19 100 80 01 12.73 +22.8 57.6 +20.1 -3.6 3.96 12.93
5473 -17.8 4.17 100 80 01 12.84 +24.0 57.6 +18.4 -3.5 4.05 12.89
5491 -17.8 4.25 100 80 00 12.94 +23.9 59.5 +18.3 -3.3 4.00 12.81
5555 -17.8 4.13 99 80 00 13.26 +23.9 61.5 +18.3 -3.2 4.09 12.78
5602 -17.8 4.33 100 80 00 13.34 +22.7 62.3 +18.3 -3.1 4.09 12.71
5649 -17.8 4.21 100 80 01 13.23 +22.9 62.5 +18.2 -2.9 4.07 12.67
5698 -17.8 4.17 99 80 00 13.37 +22.7 63.4 +18.4 -2.8 4.13 12.61
5747 -17.8 4.29 100 90 00 13.62 +22.8 65.1 +18.0 -2.1 4.21 12.56
5797 -17.8 4.31 100 80 00 13.67 +22.9 65.7 +18.3 -2.7 4.13 12.52
5817 -17.6 4.27 100 90 00 13.78 +23.0 67.2 +18.3 -2.6 4.11 12.46
5868 -17.8 4.25 100 90 00 13.89 +22.8 68.1 +18.5 -2.8 4.17 12.46
5920 -17.8 4.29 100 90 01 13.34 +22.7 65.9 +18.8 -3.7 4.17 12.46
5984 -17.8 4.25 100 90 01 13.03 +24.8 64.9 +18.8 -3.7 4.17 12.56
5995 -17.6 4.27 100 90 00 12.96 +25.9 64.0 +19.1 -4.2 4.15 12.68
6049 -17.8 4.25 99 90 00 12.86 +25.8 63.7 +19.5 -4.2 4.17 12.83
6105 -17.8 4.31 100 90 00 12.75 +25.8 63.6 +20.0 -4.3 4.15 12.93
6138 -17.8 4.35 100 90 00 12.89 +26.9 65.7 +20.2 -4.3 4.13 12.96
6207 -17.8 4.39 100 90 00 12.71 +25.9 65.5 +20.6 -4.3 4.11 12.99
6242 -17.8 4.37 100 90 00 12.68 +25.8 66.1 +20.8 -4.4 4.19 12.93
6313 -17.6 4.41 100 90 00 12.75 +25.8 66.8 +21.5 -4.4 4.19 12.89
6325 -17.8 4.39 99 90 00 12.70 +26.7 66.6 +21.6 -4.4 4.17 12.89
6385 -17.6 4.37 99 90 00 12.82 +26.8 68.0 +21.9 -4.4 4.17 12.78
6422 -17.8 4.39 99 90 00 12.73 +27.9 68.3 +22.0 -4.3 4.21 12.78
6472 -17.8 4.37 98 90 00 12.64 +28.9 68.0 +22.5 -4.3 4.27 12.78
6523 -17.8 4.37 98 90 00 12.55 +27.9 67.6 +22.7 -4.3 4.19 12.78
6535 -17.8 4.41 98 90 00 12.50 +28.6 68.3 +22.7 -4.2 4.23 12.83
6613 -17.8 4.41 99 90 00 12.57 +28.9 67.9 +22.5 -4.2 4.23 12.81
6653 -17.8 4.41 99 90 00 12.50 +29.2 68.9 +22.5 -4.2 4.23 12.74
6693 -17.8 4.39 99 90 00 12.23 +29.2 67.7 +22.5 -4.2 4.21 12.78
6693 -17.8 4.41 99 90 00 12.39 +29.2 69.6 +22.5 -4.2 4.21 12.75
6734 -17.8 4.37 101 90 01 11.90 +29.2 66.8 +21.5 -4.2 4.21 12.78
Old Nov 12, 2010 | 06:29 PM
12AutoX's Avatar
12AutoX
rpm_________TPS_Load_Knok__ECU IGN__MOD IGN_______AFR
4952 -17.8 3.92 75 80 00 11.93 +22.9 49.2 +17.5 -2.0 3.92 12.52
4975 -17.8 3.94 75 80 00 11.81 +23.1 47.9 +17.4 -2.2 3.88 12.67
5012 -17.8 4.01 73 80 00 11.75 +22.9 48.4 +17.0 -2.8 3.82 12.78
5027 -17.8 3.98 72 80 00 11.19 +23.0 46.6 +17.0 -2.9 3.80 12.83
5058 -17.8 3.96 73 80 00 11.31 +21.0 47.6 +17.1 -2.9 3.80 12.86
5073 -17.8 3.98 73 80 00 11.27 +20.9 47.7 +17.4 -3.2 3.86 12.86
5112 -17.8 3.94 74 80 00 11.40 +21.1 48.5 +17.5 -3.3 3.86 12.89
5144 -17.8 4.01 73 80 00 11.15 +21.9 47.5 +17.7 -3.5 3.82 12.92
5175 -17.8 3.98 74 80 00 11.10 +22.1 47.7 +17.8 -3.6 3.78 12.93
5175 -17.8 4.01 76 80 00 11.42 +22.0 49.5 +17.9 -3.7 3.86 12.96
5216 -17.8 4.07 79 80 00 11.77 +21.0 50.7 +18.2 -3.9 3.92 13.03
5241 -17.8 4.09 78 80 00 11.51 +23.9 50.2 +18.4 -4.0 3.86 13.09
5265 -17.8 4.01 72 80 00 10.99 +23.0 48.1 +18.5 -4.2 3.76 13.06
5291 -17.9 3.86 67 80 00 9.59 +26.0 43.1 +18.3 -4.2 3.72 13.09
5299 -17.8 3.90 69 80 00 9.92 +25.9 43.8 +18.1 -4.2 3.76 13.20
5333 -17.8 3.98 72 80 00 10.85 +23.8 49.0 +17.8 -4.0 3.84 13.28
5350 -17.8 3.98 71 80 00 11.17 +23.8 49.9 +17.7 -4.0 3.86 13.39
5367 -17.8 4.00 72 80 00 11.15 +23.0 49.9 +17.5 -3.7 3.80 13.36
5393 -17.8 4.07 75 80 00 11.99 +22.9 53.7 +17.5 -3.8 3.94 13.28
5428 -17.8 4.09 77 80 00 11.93 +24.0 53.8 +17.1 -3.7 3.94 13.17
5446 -17.8 4.11 76 80 00 12.27 +23.8 55.6 +17.0 -3.6 3.92 13.03
5455 -17.8 4.11 76 80 00 12.06 +23.8 54.8 +16.8 -3.5 3.90 12.96
5491 -17.8 4.09 77 80 00 11.97 +23.9 54.5 +16.4 -3.4 3.94 12.89
5482 -17.8 4.09 76 80 00 12.15 +23.8 55.5 +16.4 -3.4 3.96 12.78
5527 -17.8 4.13 76 80 00 12.27 +23.8 56.6 +16.4 -3.3 3.92 12.78
5555 -17.8 4.05 76 80 00 12.23 +23.9 56.4 +16.5 -3.3 3.98 12.74
5602 -17.8 4.13 77 80 00 12.50 +23.7 58.4 +16.6 -3.1 4.01 12.68
5592 -17.8 4.13 76 80 00 12.54 +24.0 58.3 +16.7 -3.1 4.00 12.67
5668 -17.6 4.11 75 80 00 12.20 +24.0 58.4 +16.7 -3.0 4.03 12.56
5737 -17.8 4.13 75 80 00 12.43 +24.7 59.3 +16.9 -2.8 4.00 12.53
5688 -17.8 4.15 75 80 00 12.16 +24.9 57.5 +16.6 -2.9 3.94 12.46
5688 -17.8 4.13 76 80 00 12.34 +25.0 58.2 +16.7 -2.9 4.05 12.46
5737 -17.8 4.17 76 80 00 12.61 +24.9 62.0 +16.8 -2.6 4.11 12.46
5920 -17.8 4.21 76 80 00 12.73 +24.8 63.1 +17.5 -3.0 4.05 12.46
5698 -17.6 4.17 70 80 00 11.97 +24.9 56.8 +16.5 -2.9 3.88 12.46
5827 -17.8 4.01 73 80 00 11.29 +25.9 54.4 +17.1 -2.6 4.03 12.46
5797 -17.8 4.13 73 80 00 12.48 +24.8 60.3 +17.1 -2.8 4.05 12.52
5868 -17.8 4.15 75 80 00 12.18 +25.9 60.2 +17.4 -2.7 4.03 12.46
5847 -17.8 4.23 77 80 00 12.70 +24.9 61.9 +17.3 -2.8 4.11 12.46
5858 -17.8 4.31 82 80 00 13.67 +24.8 67.4 +17.0 -2.9 4.11 12.49
5910 -17.8 4.33 82 90 00 13.19 +24.8 65.1 +16.6 -3.5 4.09 12.45
5952 -17.8 4.27 82 90 00 13.12 +24.9 64.9 +16.7 -3.7 4.13 12.52
5963 -17.8 4.25 82 90 00 13.10 +25.8 65.0 +16.8 -3.7 4.07 12.61
5973 -17.8 4.29 83 90 00 13.03 +25.7 65.1 +17.0 -3.9 4.09 12.71
6027 -17.8 4.29 88 90 00 12.96 +25.8 64.9 +17.1 -4.2 4.11 12.78
6049 -17.8 4.31 90 90 00 12.82 +25.7 64.5 +17.3 -4.2 4.07 12.89
6071 -17.6 4.31 90 90 00 12.82 +26.9 64.8 +17.6 -4.2 4.07 12.92
6060 -17.6 4.33 89 90 00 12.82 +25.9 65.0 +17.7 -4.2 4.11 12.93
6116 -17.8 4.33 87 90 00 12.96 +26.7 66.1 +18.0 -4.2 4.15 12.99
6161 -17.6 4.37 81 90 00 12.78 +26.0 66.2 +18.5 -4.3 4.17 12.99
6184 -17.8 4.39 79 90 00 12.84 +25.7 65.5 +18.3 -4.3 4.11 12.99
6207 -17.8 4.29 79 90 00 12.61 +26.9 64.9 +18.6 -4.3 4.11 12.93
6184 -17.6 4.35 79 90 00 12.38 +27.7 65.7 +18.6 -4.3 4.17 12.89
6230 -17.8 4.35 79 90 00 12.91 +27.8 65.9 +18.8 -4.3 4.15 12.75
6253 -17.8 4.35 79 90 00 12.84 +27.9 66.8 +19.2 -4.4 4.17 12.74
6277 -17.8 4.21 72 90 00 10.97 +26.9 57.0 +19.2 -4.4 4.00 12.74
6289 -17.8 4.17 70 90 00 10.80 +29.0 56.4 +19.3 -4.4 3.96 12.75
6325 -17.8 3.92 42 80 00 8.82 +30.8 40.3 +19.8 -3.7 3.50 12.78
Old Nov 16, 2010 | 09:48 AM
athenG's Avatar
athenG
That is your problem. If you want full control of your timing then you have to tune with Speed Density. I know it suck for NA using speed density because of the limited resolution. MAF pulldown only subract/add on what the ECU numbers so the numbers will be different every time. Have you read the manual? try reading it 10x and things will be clearer... The only way to have full control of your Fuel and Timing with Utec is tuning speed density. This is why FI'd guys tune with speed density.
Obadabot
Jun 18, 2023 11:31 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
