OEM wideband adapter for Dynojet wideband plug
Old Jun 24, 2011 | 06:46 AM
Andrei's Avatar
Andrei
Default OEM wideband adapter for Dynojet wideband plug
Does anyone know of an adapter to plug the OEM wideband sensors into the Dynojet wideband plug? The Dynojet uses the same 5 wire 02 sensor as the OEM sensor and the wire colors are the same. I could cut it and hot wire it but I don't want to do that.
This the Dynojet plug, OEM wideband and Dynojet wideband which plugs in the Dynojet plug.
Old Jun 24, 2011 | 08:27 AM
Andrei's Avatar
Andrei
I ended up hot wiring them and they both passed the lean and rich test. Still want an adapter if anyone knows about one.
Old Jul 28, 2011 | 08:50 PM
sticky667's Avatar
sticky667
not sure if you found one.. but it appears that the PLX "type B" harness is the same as the OEM nissan wideband.
you can buy the TYPE B harness from www.plxdevices.com/accessories.html
then cut off the PLX connector and wire up the Dynojet(bosch) one which you can purchase from here:
http://wbo2.com/cart/orderpages.htm
scroll all the way to the bottom and in the dropdown menu select "6066 connector kit"
Bosch number is 0 258 006 066
good luck.
350z82
Oct 1, 2015 06:25 PM
