Anyone using E85 with uprev?
def not worth on NA unless you had some sort of flex fuel option. starting params, decel, everything is different, so you need completely separate maps for various concentrations of ethanol.
if you dont drain your tank all the way before you swap fuels, it will run like junk. thats the biggest drawback. unless you can always stick to 1 fuel, its not worth the hassle
Then again i knew someone who would fill up 2/3 93 1/3 e85 and ran a slightly richer tune and was fine.. its really all about playing around with it and being comfortable with tuning yourself. e85 is not something i would suggest for someone who has to take it to a shop to get a re-tune.
