Haltech main setup !!!
Old Sep 9, 2011 | 03:10 PM
qxz9027mkii's Avatar
qxz9027mkii
Default Haltech main setup !!!
On the ECU Manager Main Tab under the Mass Air Flow Settings --> Output Type --> Mass Air Flow Sensor.
i have an error that states (Requires 'MAF Sensor 1' to be assigned to an analog input)
How can i do that since the input tab on the ecu manager doesn't have inputs assignation similar to the Haltech sport 2000 input tab. (Attachment 1)
In Outputs what does the MAP Output Tab represents and are these the correct Values. (Attachment 2)
In Inputs under the MAP Tab is the values in the table are correct since I'm using the internal map on the ecu which is rated to 22psi. (Attachment 3)
Attached Thumbnails Haltech main setup !!!-main-tab.jpg   Haltech main setup !!!-map-output-tab.jpg   Haltech main setup !!!-map-input-tab.jpg
Old Sep 9, 2011 | 03:32 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Don't worry about the error, it is because you are using newer software than the last update to the 350Z box. Disregard it.
The internal map sensor calibration is fixed in the ecu, you can not edit it. The Input-Map calibration is for external map sensor only.
Old Sep 9, 2011 | 04:25 PM
qxz9027mkii
Thanks alot Hal,,,
350Z_Al
Oct 29, 2020 07:44 PM
