Stuttering, rpm spikes and drops
Old Sep 22, 2011 | 11:51 AM
marra23's Avatar
marra23
Default Stuttering, rpm spikes and drops
Help needed.
Every now and then my car hesitates and stutters for a second and then it fine again.
I checked my data logs (haltech) and found AFR to be OK.
I checked rpm and ignition and found huge drops and spikes up to 9000rpm or drops to 200rpm for a split second.
My first thought was crank angle sensor, replaced this but the problem is still there and getting worst
Here's a data log
Old Sep 22, 2011 | 12:36 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Could be cam sensor as well, start with intake cam sensor bank 1 (pass side).
Email me your log please.
Old Sep 22, 2011 | 12:48 PM
marra23's Avatar
marra23
Will do tomorrow when I have access to my email.
I did some searching and found some issues way back about APS claiming some trouble with crank angle sensor wire picking up noise, could this be similar?
https://my350z.com/forum/forced-indu...must-read.html
Old Sep 23, 2011 | 04:57 AM
Dynosty's Avatar
Dynosty
^ this would be a very rare case if so, but not impossible. You can test the signals at the ecu connector with a scope to see if there are any problems. I think most of the shielded crank sensor problems were unichip specific.
Old Sep 25, 2011 | 12:40 PM
marra23's Avatar
marra23
I found it got worse traveling on bumpy roads, so I was thinking a bad connection or earth. Check everything on the cars side once more and nothing changed.
So drop the fuel pressure, took the Haltech out and run it partial throttle and no more stumbling. So it must be the Haltech or PnP harness then. Sad this Haltech is only month old after my tuner messed up my previous one.
F/I is killing me
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
Justin100
Nov 29, 2015 03:58 PM
