Rear O2 function and input
and you mention full standalone, i was heavily considering going with aem for tuning, but tuners on here said it did not work well
i would put cats on, but i need to get the hot nitrous burn out of my engine as fast as i can. i had cats on a nitrous motor before and i had bad heat problems. i will also have a cutout before the muffler, so it would be silly to have cats and then a cutout, since getting the exhaust out as fast as i can is a priority.
the rear o2's still work without cats when u put them in the exhaust flow. The emissions control gets upset (catalyst codes) but that's it. A/F's are good.
When it's time to pass emissions testing in an obd2 state like MD I put the non-foulers (extensions) back on, enable all emissions codes, drive for 20 miles or so and it passes. It usually takes 50-300 miles until lean codes trip with anti foulers; plenty of time to get thru emissions with flying colors LOL.
I have to actually see the cats when I do CA inspection, interesting. Plus I know the smell of a bad cat and a missing cat is worse, EVO guy tried sneak one through once. There is a new OBD II+CAN based smog testing machine coming that I'm pretty sure can detect reprogramming. It will finally read VIN's too. Even my pocket scanner can do that but not my BAR97 POS.
Can you look at your datastream and see if the ECU is still doing the lean/rich injector pulse width switching? I'm thinking there is a default mode that I was never told about.
So, although not what you asked for, djamps, i did logging on the way to work this morning. It was only about 10 minutes of constant on the freeway, but i saw the A/F's sitting stead about 14.4.
How long constantly cruising do you have to travel before you start seeing the problem? based on your logs.
But please tell what year of Z/G you have. We already have evidence that not all years/models behave the same way.
30 miles constant? wow, ok, so that's going to be quite the specific condition, i'm assuming you mean constant without any changes at all in that time?
I'm running an '04.5
rear o2 behavior confirmed on an 06.
I don't know about constant... whatever it takes to get all the systems 'ready' state like you're about to try to pass emissions.
Hmm, would like to kind of merge these two threads really, some good info in the other one.
There does seem to be an easier way to re-produce. We don't know if it happens on all cars, but i'd love to know if i can repro it on mine.
If disconnecting the rear o2's actually does stabilize things it might be the best thing to do if you have test pipes.
I wonder if them off/unheated in the hot exhaust could damage or foul them up them over time though.
This all came about when I was troubleshooting the exact symptom I described -- too rich sometimes, **** mpg's, ECU overcorrecting and throwing lean codes on both banks. After doing the usual and passing with flying colors (smoke test intake and exhaust), I took extended drives and logs with and without nonfoulers. As a self-tuner I'm extremely **** about my tune and this was driving me crazy. I was relieved to discover the 'problem' was really so simple.
As you can guess, the non-foulers stayed off my car and never had a code or overfueling since. Went from <18mpg to 25+ on the freeway and the car is noticeably more peppy at part throttle.
I have an 05 6 speed sedan with a full Non-Revup swap, new 04.5 ECM and new harness. The Revup ECM never complained like a ***** and took non-foulers and ran hard with no codes and it was ready for full on power after a reset and pulling out of the driveway unlike this 04.5 one which continues to SEVERELY **** me off.
This is the amount of codes that come up when they are disconnected. Worse than a German car.
P0139,02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0159,02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P1146,Heated O2 Sensor 2
P1166,Heated O2 Sensor 2
P1147,Heated O2 Sensor 2
P1167,Heated O2 Sensor 2
This is to be expected. You have to delete the P04x0 codes. If you are throwing other codes with all sensors in the exaust stream then you have another issues like exhaust/vacuum leaks, bad tuning, ect.
And any car that is not a Revup will have this issue, all the way up to the 07 automatic G35 coupe. Any one who doesn't have a Revup and who have test pipes and use straight non-foulers have this issue and don't know it because there is no codes. They just think it runs normal when it actually doesn't because they don't know the difference. I do.
