Rear O2 function and input
Old Apr 30, 2012 | 08:39 AM
  #121
F2CMaDMaXX's Avatar
F2CMaDMaXX
djamps, fancy looking at that log i posted? or if you did already, did you see anything else?
Old Apr 30, 2012 | 11:12 AM
  #122
Neimad's Avatar
Neimad
Andrei- Isn't your thermostat missing?
Old Apr 30, 2012 | 11:50 AM
  #123
Andrei's Avatar
Andrei
Yes I am not using it currently. This condition happens with or without a t-stat and the temp in 75-90 degrees without a t-stat is only cooler by 10-13 degrees F after warm up period.
Old Apr 30, 2012 | 11:52 AM
  #124
Neimad's Avatar
Neimad
So whats your fuel trim readings after it starts? If you can post your whole datastream at that point it would be cool.
Old Apr 30, 2012 | 02:03 PM
  #125
Andrei's Avatar
Andrei
I can log it tonight when I go home around 1AM. It will be cooler outside and the air will be denser so it will run slightly better than right now when it's 90 degrees outside so it wont be a "true" log.
I'll do a 3rd gear pull or 2 half way home. I don't like doing pulls when it runs bad because the exhaust is raspy and really annoying, dual 3". Sounds perfect when it runs normal.
I was lazy to log pulls only. First file has 1st and 2nd gear pulls and second file has 1 3rd gear pull. It was 76 degrees outside.
http://www7.zippyshare.com/v/8526585/file.html
Old May 1, 2012 | 07:38 AM
  #126
Onggiatuan2's Avatar
Onggiatuan2
Default 02 sensor
Looking to buy an 02 sensor, bank 1 sensor 2
Old May 1, 2012 | 07:47 AM
  #127
djamps's Avatar
djamps
umm, wrong thread guy.
Old May 3, 2012 | 09:47 AM
  #128
karletto66's Avatar
karletto66
In my HR engine with Berks Kat (with foulers on O2 sensors) and UPREV tune i never had problems also at cruise speed, i made some logs for testing some months ago and A/F was as expected.
BUT i have to admit that never try to drive at the same speed for 50 km, in Italy is simply impossible also on highways....
And a 350Z is NOT made for cruise speed so...not a problem for me !
Old May 3, 2012 | 11:05 AM
  #129
Andrei's Avatar
Andrei
The Revup, HR and VHR don't have the problem discussed in this thread. And the driving conditions required to experience this problem are not really required, as I noticed. If you drive it under any conditions except the ones in the FSM to experience this problem, it will have this problem eventually anyway.
Old May 3, 2012 | 12:15 PM
  #130
F2CMaDMaXX's Avatar
F2CMaDMaXX
I still have not see a CEL or any problems from this.
It was also found that just hard WOT rev when stood still would trigger the lean/rich condition on one bank, if not the code. I still cannot do this, which i have to assume is good, for me at least.
Where is the guy who unplugged his rear sensors? i'm really interested in his results now he's done it for a few weeks.
Old May 5, 2012 | 04:14 PM
  #131
Andrei's Avatar
Andrei
djamps is correct. Today I welded on short .50" bungs and put the sensor directly in the exhaust stream, and plugged the longer Megan bungs. Ran perfect in less than 2 miles without a reset or clearing learned fuel trims. I'm expecting even more power with the stock tune, since the current tune was done with the non-foulers. And even more power once it's properly tuned.
This is what it looks like. I am pleased and satisfied now.
Old May 7, 2012 | 01:17 PM
  #132
mgrotel's Avatar
mgrotel
djamps for president!!!
Old May 7, 2012 | 02:04 PM
  #133
djamps's Avatar
djamps
Good stuff. How did we come to the conclusion this issue does no affect revups? I see HR guys say there aren't problems but who has a revup who can confirm?
Old May 7, 2012 | 08:26 PM
  #134
F2CMaDMaXX's Avatar
F2CMaDMaXX
I'd love to see a common occurrence, but remember it's not affecting mine either.
Old May 7, 2012 | 11:18 PM
  #135
djamps's Avatar
djamps
Could you confirm which ROM you're using? AC405 or AC406?
Also, it could matter what kind of antifouler you have... some are very long and some are short. Mine were short ones (about 1"). Maybe the long ones like on art pipes don't send the ECU a usable reading but short ones send a 'believable' but slightly wrong reading which the ECU makes corrections on.
Old May 8, 2012 | 07:24 AM
  #136
djamps's Avatar
djamps
So there is more of an impact than just closed loop operation.. looks like you could lose your cam control if you have rich/lean/o2 codes (not including catalyst codes of course)! This is a serious low/mid-range hit:
https://my350z.com/forum/tuning/5548...he-faults.html
Old May 8, 2012 | 11:08 AM
  #137
F2CMaDMaXX's Avatar
F2CMaDMaXX
Didn't someone else come in and dispute that theory? interesting though.
I will have to check which ROM, but agreed on the type of anti foulers, the ART's are long and curved, has to make a difference.
Old May 8, 2012 | 11:51 AM
  #138
str8dum1's Avatar
str8dum1
codes that could cause cam error are
P0171 P0174
P0172, P0175
at least from what I was told and have experienced. Hopefully my cipher cable comes tomorrow so I can test some.
Old May 8, 2012 | 04:26 PM
  #139
F2CMaDMaXX's Avatar
F2CMaDMaXX
Could you confirm which ROM you're using? AC405 or AC406?....
Sorry, you're going to have to help me out here, i'm not seeing either of those two numbers, where am i looking for them?
Old May 9, 2012 | 02:18 PM
  #140
Andrei's Avatar
Andrei
I had it. Ran for over a year without problems with test pipes and 90 degree non-foulers. The Revup is really more of an HR than a DE. Right now one bung is leaking and I found it with Seafoam. Going to fix it tomorrow.
