Osiris + Monitoring Knock?
Old Sep 19, 2012 | 11:38 AM
NFGZ's Avatar
NFGZ
Default Osiris + Monitoring Knock?
I noticed cypher has no way to monitor knock ... what do you guys do to monitor this? Just watch for timing to be pulled?
Old Sep 25, 2012 | 05:00 PM
djamps's Avatar
djamps
headphones.
https://my350z.com/forum/tuning/5423...en-device.html
Old Sep 30, 2012 | 09:24 AM
binder's Avatar
binder
listening is the best if you know what it sounds like. Stock knock sensor sucks. Every engine is different so the stock settings don't always conform to your exact engine.
Old Oct 3, 2012 | 01:34 AM
karletto66's Avatar
karletto66
I think that if you use (if you have TUNER) Rom Editor to log data there is "knock log"...
Old Oct 3, 2012 | 02:51 AM
tcode's Avatar
tcode
Originally Posted by djamps
What about 5k+ rpm range. Can you still recognize knock between all that engine noise?
Old Oct 3, 2012 | 05:38 AM
djamps's Avatar
djamps
Yes it's straight forward especially with good noise cancelling headphones.
Old Oct 3, 2012 | 06:29 AM
binder's Avatar
binder
well, listening to knock should be performed by someone who is trained. Knock has a distinctive sound and is very noticeable over normal engine noises.
I would not rely on the crappy knock sensors we have in these cars. The knock tables aren't set up properly and a lot of engine noise is picked up. It also doesn't help that the ecu is only programmed to use the knock sensor up to 5000 rpm.
350z_z33.
Jul 3, 2017 04:01 AM
NissanZcrazy
Nov 2, 2015 06:03 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
hulkout
Tuning
Sep 18, 2015 05:42 AM
