boost without standalone?
Old Feb 5, 2013 | 01:03 PM
black3.5z's Avatar
black3.5z
Default boost without standalone?
ok just a quick question. where I live (Canada) there are no tuner shops for miles like 15 plus hours away
If i were to twin turbo with a greddy kit and stay at 6 psi can i go with a chip tune have the ecu reflashed or is it even possible i had a guy mention this to me but im not sure i like the idea of that doesnt sound reliable. and if i do install it is there any possible way i can make it driveable to take it to get it tuned if i ran a haltech
Old Feb 5, 2013 | 02:53 PM
ocdz's Avatar
ocdz
Plenty of people have run boost with uprev (what you're referring to when you say ecu reflash chip tune). And lots of places can e-tune for you if you are not near a certified or trusted tuner. It probably wouldnt be as good as having it tuned in person but its an option.
Old Feb 5, 2013 | 02:59 PM
godzilla619's Avatar
godzilla619
why would you spend the $8-15k on a FI kit and not get it as dialed in as possible? my advice would be to have you car shipped to a reputable installer and tuner and pick it up when done or get the etune to be able to drive it to a good dyno tuner.
Old Feb 7, 2013 | 08:29 AM
black3.5z's Avatar
black3.5z
i plan on installing the kit my self the point would be to get the tune so i could drive to a shop and have it tuned properly to get rid of the shipping or trailering cost. ever try crossing the boarder to the states with a car on the trailer they don't believe your not buying anything.
so with the uprev how does that work do i send my ecu away with the specs of the car?
i mean i don't like the idea or running the car like that but its really my only option. there is one shop here has only ever tuned 2 350z and blew one up never even left the shop blew on the dyno was the shops fault.
i dont have the car support around here like the states does if you want something you pay out your *** for it. and there might be 10 z's in my city and thats it i boosted car is even rare to see.
Old Feb 7, 2013 | 09:08 AM
godzilla619
most turbokits come with some form of ems or tune. those would be good enough to get you to a tuner as long as you are not getting into boost.
uprev uses an obd2 plugin dongle that you then connect to a laptop. you upload the tune through that. the tuner version also allows you to change any of those parameters yourself. both versions have data logging though. to get a e tune they will ask you to do a drive while datalogging they will then send you an etune that you will then upload to your car.
my suggestion would be to install your kit upload the tune supplied with your kit, then pay the $50 for an etune and data log your car while driving and upload the etune based off that, then drive it somewhere to have it dyno tuned if you want.
Old Feb 7, 2013 | 09:52 AM
black3.5z's Avatar
black3.5z
ok that sounds like my best plan. do the kits come with the programs for the computer? also do they work for mac?
so they would email me the new map and then i upload it?
Old Feb 7, 2013 | 11:26 AM
binder's Avatar
binder
Is there any dyno around you? You can get a remote log in tune if you have a shop that can run the dyno while someone logs into the computer. Hal offers remote services with haltech.
With the wild variances in atmosphere, engines, turbo kits even a standard "flash tune" there can be quite a bit of danger.
Old Feb 7, 2013 | 02:18 PM
godzilla619
with his budget i doubt he has the money for a stand alone like the haltech. it all depends on what kit you buy, some have tuner kits where you supply your own. first narrow it down to what kit you are going to buy. then contact a reseller/manufacturer of the kit about engine managment. without knowing what kit in what configuration you are going to run it's all pretty much pointless.
Old Feb 9, 2013 | 08:30 AM
black3.5z's Avatar
black3.5z
there is a dyno about two hours from me they only work on muscle cars tho. thats the thing i don't have any shops i can go to. i do plan on going with the haltech. I plan on going with the greddy kit
Old Feb 9, 2013 | 08:53 AM
RUNWDVL's Avatar
RUNWDVL
Greddy package usually come with a tuner program. If you go uprev it's not Mac compatible. I had to get a cheap refurbish hp lap top. There are option. Haltech would be the best scenario.
Old Feb 10, 2013 | 08:36 AM
binder's Avatar
binder
So what's the budget? The used haltechs on the market now make them a cheaper option than osiris and you have all in 1 not piecing together things like a logger, a/f, and boost control separately. Some are selling for around 1000$
Also, just because they only do muscle cars doesn't mean anything. There aren't any tuning shops around me here but they will GLADLY charge you to use the dyno. You pay them to run the dyno (not car specific) and you have your computer going with Hal logged into it. Simple.
I would highly doubt a shop would turn down easy money like that.
Old Feb 10, 2013 | 03:32 PM
black3.5z's Avatar
black3.5z
ok i think i see what you are saying I just run the car and hal watches the data record as the car runs on the dyno. there is a fair bit I need to understand before I start my process i'm in a I guess you can say the planning stage right now
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
