Up Rev Tuned
Old Sep 14, 2017 | 04:01 PM
NO PLN B's Avatar
NO PLN B
Default Up Rev Tuned
I had a local tune shop tune my car using UpRev software. I paid for the software but only got the tune no Interface cable. With no interface cable can I take my car to another tune shop and have them access my computer ?
Old Sep 14, 2017 | 04:24 PM
BigBlue's Avatar
BigBlue
By "software" do you mean a license was flashed onto your ecu? If so then all you need is a cable.
If not, better to just buy a cable with a license on it from UpRev and problem solved; e-tunes/live tunes or do it yourself if you get the tuner setup. Good luck with it.
Old Sep 14, 2017 | 06:05 PM
seymore4's Avatar
seymore4
Professional
When you go to a shop and get dyno tuned all you get is the Osiris license flashed onto your ECU and the tune. No interface cable.
Any other Uprev tuner can plug in and retune your car, no problem.
Old Sep 14, 2017 | 09:29 PM
bad boyz's Avatar
bad boyz
Blue, I'm also looking to get a tune so should I just go to uprev and by the license and the cable and what's the difficulty of doing it myself?
Old Sep 15, 2017 | 05:31 AM
RedBullRR's Avatar
RedBullRR
Can I buy a UPREV Cable and it will recognize my License? I had gotten my car tuned paid for the license but now have moved to another state.
seymore4's Avatar
seymore4
Professional
If you know a little about tuning or are at least willing to learn (just takes time) the tuner version does give you a lot more options.
Old Sep 15, 2017 | 05:34 AM
seymore4's Avatar
seymore4
Professional
Yes.
Old Sep 15, 2017 | 05:50 AM
iideadeyeii's Avatar
iideadeyeii
can we not
https://my350z.com/forum/tuning/6172...l#post10915250
Old Sep 15, 2017 | 06:00 AM
travlee's Avatar
travlee
Master
i was thinking the license is married to the cable, or something to that affect
Old Sep 15, 2017 | 06:02 AM
seymore4's Avatar
seymore4
Professional
It is not. You can use any unlicensed cable, tuner or standard, new or used.
Old Sep 15, 2017 | 08:40 AM
NO PLN B's Avatar
NO PLN B
Default Thanks for the help
Yes my ECU has already been flashed with a gain of 25 more HPRW. Good tune. Just thinking of the future if I decide to go to another tune shop. 2006 350 Z cool air,custom exhaust cat back
Old Sep 15, 2017 | 08:42 AM
travlee's Avatar
travlee
Master
I doubt you gained 25.
Old Sep 15, 2017 | 09:00 AM
seymore4's Avatar
seymore4
Professional
Any Uprev tuner can retune your car.
Old Sep 15, 2017 | 09:24 AM
CK_32's Avatar
CK_32
Yea I think the cable is the actual license holder. Not the OBDII.
I got both so I'm not 100% sure but I think it's the cable. Cause when you look for your license and info it's under cable management.
Old Sep 15, 2017 | 11:58 AM
BigBlue's Avatar
BigBlue
Yeah Trav, when you flash your license for the first time from the uprev cable it puts it into the ecu. You can at any time put the license back onto your cable, then flash it onto another car, etc. Some guys do this (after the "back to stock" option when selling their Nissan keeping their valuable cable/license.
Old Sep 15, 2017 | 12:01 PM
travlee's Avatar
travlee
Master
So i was half right....ha
Old Sep 15, 2017 | 12:08 PM
BigBlue's Avatar
BigBlue
Yeah like Seymore said with the tuner version you or someone who is good at tuning yourself would be the way to go; costs I think $150+ more than the standard cable + license.
Old Sep 15, 2017 | 02:38 PM
NO PLN B's Avatar
NO PLN B
listen Travlee!! It's my friend that dynode my car. I was standing right there I saw the gaines I saw the differences and there were some modifications if you don't know don't spout off like you know something
Old Sep 15, 2017 | 03:27 PM
travlee's Avatar
travlee
Master
So what was your final number mr short fuse?
Old Sep 15, 2017 | 03:54 PM
NO PLN B's Avatar
NO PLN B
travelee listen. This will be the last Time I respond to you. You seem like a very unhappy individual that needs to be right. I have better things to do, and I don't have to explain anything to you. So if you would like you can believe that you're right and I'm wrong have a nice day
