Pig rich issue
Old 09-21-2017, 06:02 AM
nddavis2
nddavis2's Avatar
Default Pig rich issue
Ok guys I haven't posted in quite a while now but my car is running and I have 1 huge issue. The front 02 sensors are reading a static 14.7:1 ratio which is causing the ecu to dump the max amount of fuel into the system. Wideband is reading 11.2 so it's stupid rich. Replaced both front 02 sensors and it changed nothing. Continuity, voltage, resistance, and ground are all good. Myself and the tuner are not sure exactly where to go from here. Any ideas guys?
car was able to be tuned to WOT and runs smooth throughout the rpm range however I can't daily it this rich. Tuner used an external wideband to tune with however it read the same as my aem one.
Old 09-21-2017, 02:09 PM
MatthewBouchard
MatthewBouchard's Avatar
Have you reset your ecu?
Reset that ECU and see if your AFR goes back to normal for a little bit.
Old 09-22-2017, 01:38 AM
nddavis2
nddavis2's Avatar
I'll try that again today when I get the car back in my possession. I'll get the tuner to do it and watch the afr to verify.
Old 09-22-2017, 02:40 PM
nddavis2
nddavis2's Avatar
It idles at 14.7 foe just a few seconds before dropping back down to 11.5-12.2. First car I've had run rich that did not smell like it had leftover fuel.
Old 09-22-2017, 10:51 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
build?
NA/FI?
tuning device?
Old 09-22-2017, 11:13 PM
nddavis2
nddavis2's Avatar
Nothing special. 03 with bolt ons only. Intake, headers, exhaust, and plenum spacer th ed using uprev. Car drives great just a/f reads too rich.
Old 09-22-2017, 11:34 PM
bealljk
bealljk's Avatar
can you rent/borrow/buy a standalone o2 sensor to confirm/deny the OEM o2s??
How is your gas mileage??
Does it smell rich?
Can you unbolt them (partially or fully) or pick up o2 cheaters to get some variance on the o2 sensors?
Old 09-24-2017, 08:55 AM
nddavis2
nddavis2's Avatar
Using an aem wideband for the a/f ratio which was confirmed my the reading on the dyno. Getting poor gas mileage but doesn't smell rich out of the tailpipe surprisingly. Not exactly sure what o2 cheaters are. I know they're used for the rear sensors but not the front.
Old 12-10-2017, 02:37 PM
nddavis2
nddavis2's Avatar
These are the results I’m getting from my scanner. Notice the 100% on load_pct(%): being 100.0. Rear 02 sensors have been removed. Car starts great, idles at 14.7 a/f at the beginning then it tanks to 10.0 because 10 is the lowest it can read. All sensors have been replaced on the engine, including throttle body and o2 sensors. I’m lost...
Dtc_cnt: 0
Fuelsys1: cl
Fuelsys2: cL
Load_pct(%): 100.0
Ect(C): 82
Shrtft1(%): -7.8
Longft2(%): -10.2
Shrtft2(%): 21.1
Longft2(%): 9.4
Rpm(rpm): 937
Sparkadv(deg): 10.0
Iat(C): 30
Maf(g/s): 5.82
Tp(%): 0.4
O2sloc: b1s12-b2s12
O2b1s1(v): .305
Shrtftb1s1(%): -17.2
O2b1s2(v):.300
Shrtftb1s1(%): n/a
O2b2s1(v): .610
Shrtftb2s1(%): .290
O2b2s2(v): .290
Shrtftb2s2(%): 99.2
My next step is ripping out the wiring harness because something is causing the injectors to run 100% duty.
Old 12-11-2017, 12:58 AM
nddavis2
nddavis2's Avatar
Also can someone tell me which ecus in 04 used wideband vs narrow band? I have an r4 ecu but my engine and harness are from an 03.
Old 08-06-2023, 04:16 PM
A2G
A2G's Avatar
Did you ever figure out what the issue was I’m having a similar problem
Old 08-06-2023, 05:18 PM
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
Almost 6 years late to the party
