PCV Crossover hose and AFR
Old Apr 6, 2018 | 08:50 AM
bcoffin23's Avatar
bcoffin23
Default PCV Crossover hose and AFR
I took my 350z to get tuned, and it was running lean (which was fixed with the tune)
I discovered the the previous owner had the PCV crossover tube detached and breathing open from the passenger side and plugged on the driver side. I have since replaced with a new PCV crossover tube which will now be equalizing pressure between the valve covers.
Is this going to throw off my AFR?
Old Apr 6, 2018 | 04:47 PM
CK_32's Avatar
CK_32
Idk you tell us. Are you reading rich now?
In theory yes it could and no it couldn’t. It’s letting air in and or out of your valve covers.
I’m going to bet on no, it’s allowing air into the sealed system, which could possibly put air into the cylanders during operation... but that’s not directly open to the cylinders so it should be making you run lean. What it should be doing is throwing oil all over your engine.
dmjddm9999
Aug 28, 2015 08:32 AM
05SickSer
Aug 25, 2012 01:34 PM
cersoft
North West
Nov 25, 2008 03:59 PM
norapat01
Dec 4, 2007 12:34 AM
z350boy
Oct 8, 2007 06:55 AM
