Greddy VQ35HR TT??!?
Old Jan 23, 2008 | 10:23 AM
  #301
bboypuertoroc's Avatar
bboypuertoroc
Originally Posted by Peak350
How are you so certain is has nothing to do with a raised redline.
More redline = more power assuming you keep the engine breathing up top.
7500/6600 = 1.136 more rev range, which should mean about that much more power than a DE given the same efficiency and boost levels....even more because of the higher compression and more efficient design of the intake manifold.
I do expect they are running more boost, but also making more power per psi of boost....
NO power comes from raising the redline AT ALL. I can raise my redline to timbucktoo but I won't make any power doing it. All it does is give you more space to POSSIBLY make more power. Like you said, it depends if your engine itself is still making power at that point.
In short (and I'm sure we're both getting at the same point), no power came from rasing the redline itself, but came from taking advantage of the extra rev range. On the same sized turbos at the same boost at near the same compression, just raising the redline alone won't make more power.
I guess I coulda worded my original statement better. I re-read it and it came out wrong. I also quoted the wrong person (I was supposed to quote you, not aloh).
Old Jan 23, 2008 | 10:34 AM
  #302
Peak350's Avatar
Peak350
My original statement also included a very key piece of information - the turbos need to be able to breathe efficiently up top.
I'm making the point I am because of how the E46 M3 kits have made power - a lot of gain is made in the last thousand RPM's, and it comes from already maxing out how much torque you can make at a certain boost level.
I still say - they will run bigger turbos and make more power at the same psi (more power gain) because the turbos breathe more efficiently, and the higher RPM range of the engine takes away the need for a "faster" spooling turbo.
edit - and we are arguing semantics now
Old Jan 23, 2008 | 10:46 AM
  #303
bboypuertoroc
I didn't miss that statement at all... I agreed with you on it -
Last I read, it's still the same turbos as the DE kit (18G's). I'd like to see them step up to 20G's, or even TD06 18G's.
Old Jan 23, 2008 | 11:21 AM
  #304
cc1012's Avatar
cc1012
its great how people automatically assume since the rev limiter is higher on the HR that it will make more power.
Old Jan 23, 2008 | 12:58 PM
  #305
Peak350's Avatar
Peak350
Thats what I was missing.
Old Jan 24, 2008 | 01:26 PM
  #306
350Z FTW's Avatar
350Z FTW
Any updates so far, any news people. I believe I saw Feb. as the next month of upates?
Old Jan 24, 2008 | 02:16 PM
  #307
robertsowka's Avatar
robertsowka
its moved to august... read one page back or EVERY page back for that matter
Old Jan 25, 2008 | 01:47 PM
  #308
Zacreth's Avatar
Zacreth
Z Rocker
Hehe...
Old Jan 25, 2008 | 01:48 PM
  #309
Zacreth's Avatar
Zacreth
Z Rocker
Old Jan 25, 2008 | 01:52 PM
  #310
bboypuertoroc
Looks so much better in the HRs than in the DEs.
  #311
robertsowka
omfg.... that is amazing........
Old Jan 25, 2008 | 01:53 PM
  #312
robertsowka
does that say vq42hr? oh man i cant wait till this comes out.....
Old Jan 25, 2008 | 05:23 PM
  #313
Peak350's Avatar
Peak350
And it has blow off valves now....hmmm Greddy is playing with more $$.
Old Jan 25, 2008 | 05:44 PM
  #314
warmmilk's Avatar
warmmilk
i like that new plenum, looks pretty badass in flat black
what i don't like though, is the lack of a strut bar, thats pretty gay, they should at least offer one made by them to replace the oem one
Old Jan 25, 2008 | 05:53 PM
  #315
bboypuertoroc
I'm sure they'll come up with something.
I think the carbon plenum is MUCH hotter.
Old Jan 25, 2008 | 06:51 PM
  #316
warmmilk's Avatar
warmmilk
^while the carbon plenum looks much better, this one looks like it has significantly more volume, and there for more top end power
Old Jan 25, 2008 | 08:10 PM
  #317
robertsowka
if the flat black one was smoother and rounded and didnt have those sharp edges i think it would be pretty badass too...
Old Jan 25, 2008 | 08:32 PM
  #318
ncparamedic's Avatar
ncparamedic
Prodigal Son
i definitely like it..
Old Jan 25, 2008 | 09:14 PM
  #319
350Z FTW's Avatar
350Z FTW
ILL TAKE IT!
Old Jan 25, 2008 | 09:39 PM
  #320
07nismoz's Avatar
07nismoz
umm.. yeah.
