Berk HFC Installed...damaged o2 sensor?
Old Dec 17, 2007 | 09:37 AM
  #41
CC Z33's Avatar
CC Z33
Sounds good. I'll call Tim up and see what he can do? Can you PM with details on how much it was. Or did they cover it under warranty even though you modified the cats. Thanks.
Old Dec 17, 2007 | 01:28 PM
  #42
Allen331's Avatar
Allen331
They covered it under warranty only because it was the o2 sensor on my header that was damaged. Upon installation of the HFCs, i only removed two o2 sensors. One from each cat. Apparently, as we were installing the cats, using an impact gun to loosen a bolt on the driver side flange, we damaged the o2 sensor on the header.
Old Dec 18, 2007 | 03:38 AM
  #43
CC Z33's Avatar
CC Z33
Oh ok. I'll give Tim a call and see what he can do. Thanks.
Old Dec 18, 2007 | 04:30 AM
  #44
VORTECH?notyet's Avatar
VORTECH?notyet
we need sound clips
Old Dec 18, 2007 | 08:27 AM
  #45
CC Z33's Avatar
CC Z33
I'm going in on Saturday morning to have it checked out. Hopefully they can take care of the problem. I'll keep you guys updated as well.
Old Dec 18, 2007 | 04:29 PM
  #46
fairlady rasir's Avatar
fairlady rasir
so removing all four censors prior to installation would be the best/safest way to avoid these type of situations?
Old Dec 18, 2007 | 04:39 PM
  #47
Allen331's Avatar
Allen331
Yup you got it. Well you have to take off the two on the cats anyways, but taking off the two on the headers would make it easier too.
Old Dec 19, 2007 | 08:55 AM
  #48
stylett9's Avatar
stylett9
with test pipes don't expect your CEL to go away. Replacing the 02 might solve the stuttering problem but your CEL will still be on.
Old Dec 19, 2007 | 09:32 PM
  #49
CC Z33's Avatar
CC Z33
The CEL doesn't bother me. It's the stuttering. So if they can at least fix that then I'm good!
Old Jan 17, 2008 | 05:31 AM
  #50
reserved's Avatar
reserved
Brief update of my HFC's
Just had the Crawford HFC's installed and, just like everyone else, removal of the stock cats (due to one bolt in particular) was extremely difficult. However, end result seems good with absolutely no CEL issues. Engine note is maybe just a little "deeper". I did not have a before and after dyno, so no idea about any power gains.
One other observation is about Crawford vs. Berk HFC's. There was a set of Berks in the shop waiting to be installed on someone else's 350Z, and compared to the Crawfords, the Berks just looked like a better "finished" product. For example, the Berks had a flange for the bolt, but the Crawfords just came with a clamp (looked kind of like an exhaust hanger) along with a warning not to over-tighten due to possible "crimping". By way of a disclaimer, let me say that I am no engineer, but if I had to make the choice over again, I would probably go with the Berks.
Old Jun 21, 2011 | 10:25 AM
  #51
OMG35S's Avatar
OMG35S
I hope you guys can chime in:
http://g35driver.com/forums/g35-seda...cel-p1148.html
Thanks!
Old Jun 21, 2011 | 03:10 PM
  #52
AadosX's Avatar
AadosX
Bank 1 is passenger side. Looks like your sensor is bad. It's very easy to replace.. just make sure you have the right tool. I suggest a regular wrench (box ended on one end and open on the other)... 7/8" is the right size I believe.. 99% sure.
Old Jun 23, 2011 | 04:00 PM
  #53
Z33_kid's Avatar
Z33_kid
hmmm sounds weird looks like they were experimenting your car... i did the install by my self in my garage had no problems
Mike@CZP
Dec 12, 2017 09:45 AM
BADASSTT
Mar 28, 2009 02:39 PM
chavoush
Sep 4, 2008 06:50 PM
JonnyC
Aug 20, 2008 04:55 PM
