it adds both. after bolt-ons the z's run lean up top. the fuel return comes with a FPR and all so it helps rich'in it up on higher rpm's. Quinton at AAM said it adds about 6hp with intake and exhaust. also, it's because the z's have crappy fuel rail setups factory. they criss-cross from side to side instead of two seperate fuel rails.
So you can upgrade to a fuel return system on your stock n/a engine, after which im sure you would get a retune?
On my car it stops at 155 not 160. I dont know if thats cuz its a base or if its all trim levels. A guy with a nismo claims to have gone 16X. But I know from personal experience that the computer stops u at 155. So we will have to wait and see what technosquare can do.
i did 149 mph on 5th gear and had a lot more to go or a least it felt like it. i have the 07 with nothing but the nismo intakes.
To the OP-
Great numbers. Even if they aren't 100% accurate, they should be good #'s. With Cams, intake, Exhaust, spacer, and HFC on my 06 the Exact Dyno measured 259 WHP. Even if your car actually has 260 that is great considering the low cost of your mods and the few bolt-ons you have.
Thanks man and yeh the numbers are 100% accurate. I just got back from PF supercars to do a comparison run on a different dyno and I ran pretty much the same hp numbers. Maybe even a little higher but I will post those numbers as well for all to see. Jon(Gooey) ran on the dyno right before me and we ran within 4hp of each other and he had the stock airboxes with K+Ns. So with the 07s Dual exhaust and tps will get you between 275-285hp.
The engine does have alot more in it, thats not a question. Others have been arguing whether or not the computer is limited, and it is. The power of the car will take you beyond that but the ECU has a governor which restricts your top speed.
Thanks man. Im curious to see what I can do to smooth that curve out a little more tho. There are some pretty serious dips in the curve and I could hear audibly that the car was stumbling a little bit.
wow, has a lot more in it if you tune that higher end for more like 13.5:1 AFR. pretty impressive numbers though for pretty near stock. also looks like it would keep making power to if not past redline with a good AFR. that power slow at 7k def looks related to the AFR
If you want to run 13.5 AFR at WOT at the higher RPMs, go for it...
I definitely agree that a tune is going to make a big difference but since its my daily driver I probably wont have the ***** to tune it to 14.0. maybe 13.5 but we will see.
14.0 AFR @ WOT near redline?? Sh*t... brave.
I'm new to the Z world so I don't know the specific tolerances... But that's uber high in other worlds for sure...
