VQ35HR specific Zex Nitrous kit just arrived
Old May 27, 2008 | 02:45 PM
powermark's Avatar
powermark
Default VQ35HR specific Zex Nitrous kit just arrived
I still cant find anyone that makes a colder plug for a HR, anyone know?
If not, I am only going to run a 75 shot, probably shoot for a 350whp 350z
They forgot 1 of the nozzles, so they are sending me another one. Since I believe so much in the stock intakes on this car, I think I am going to weld some 304 together and ditch the stock plastic pipes for the nitrous. There are adaptors (they even give you a tap) used for the OEM intakes though.
Ill be doing an install video with dynos.
Fuel Fitting that clamps the stock line and then use the small supplied line to fit back onto the other side, no cutting of fuel lines
To keep out any CELs, Zex puts a resistor on the TPS wire
just incase your still confused...
Old May 27, 2008 | 05:21 PM
itsjiggajames's Avatar
itsjiggajames
good stuff man.. are you going to run colder plugs? How detrimental do you think this kit will be for your motor in terms of engine longevity?
Old May 27, 2008 | 06:19 PM
Peak350's Avatar
Peak350
You should always run colder plugs when possible with a nitrous setup...and how is he supposed to know. Until some people blow motors and test the limits no-one can do more than speculate. 75 hp should be safe for a reasonable amount of time, but who knows how long...
And my question is....window switch?
Old May 27, 2008 | 06:35 PM
powermark's Avatar
powermark
theres no colder plug i can find as of yet.
no window switch. Ive been running nitrous in my cars for 10 years and never needed one.
Old May 27, 2008 | 06:54 PM
Peak350's Avatar
Peak350
Never really need one, its just convenient is all. I'd have one just for the "one less thing to worry about" aspect.
No-one has said colder plugs are out, best bet would be calling a shop though, edit- I knew that, I was just trying to clarify why you'd mentioned it.
Old May 27, 2008 | 10:20 PM
powermark's Avatar
powermark
im going to just try calling denso/autolite direct
im getting my 6/6 piston Baer BBK on tomorrow-thurs, so after thats done ill worry about the plugs
Old May 28, 2008 | 10:45 AM
Zacreth's Avatar
Zacreth
Z Rocker
Just curious because I know nothing of nitrous and never thought of using it, but what is this window switch that you talk about?
Old May 28, 2008 | 12:36 PM
chinny's Avatar
chinny
hmmm, if you dont mind how much did this kit set you back ? the dynotune kit is around ~$475 brand new.
Old May 28, 2008 | 12:53 PM
powermark's Avatar
powermark
2 rpm pills u put into a MSD module that intercepts a tach signal to turn the nitrous (or anything for that matter) on and off at designated RPM points
Old May 28, 2008 | 03:27 PM
tribal_visionz's Avatar
tribal_visionz
does this void you warranty like crazy?
Old May 28, 2008 | 03:32 PM
shift-er's Avatar
shift-er
only if you leave it hooked up and installed when you go to the dealer....
they dont have to know.
Old May 28, 2008 | 03:39 PM
powermark's Avatar
powermark
street price will be about $800, though they will do a discount of enough are interested
Old May 28, 2008 | 03:40 PM
powermark's Avatar
powermark
as does any major power adder, but the luxury of a plug and play kit like this is that it comes out easy.
Old May 28, 2008 | 04:01 PM
newt0n's Avatar
newt0n
lol what will you do with the bottle and bottle mount when you take it in? also quick question. what would be an rpm you would set this "window switch" to I know it is preference but obviously you dont want it at 3,000 rpms so what would be a good setting? Thinking about possibly doing this.
Old May 28, 2008 | 04:06 PM
coachk's Avatar
coachk
For the plugs check with Performance Factory since they have done a couple turbo kits on the HR's already and I'm sure they used a 1 step colder plug.
Old May 29, 2008 | 07:50 AM
07Z FoSho's Avatar
07Z FoSho
i have a dyno tune 100shot on my 07, stock plugs, stock timing, 93 oct.
have had 4 bottles though it so far, its a blast...
im going to the track tomorrow, going for high 11s at high teen traps...
powermark's Avatar
powermark
3000-3500 is ideal, shut it off right before redline
Old May 29, 2008 | 07:51 AM
powermark's Avatar
powermark
asked already, they dont know either
Old May 29, 2008 | 11:22 AM
newt0n's Avatar
newt0n
a
Old May 29, 2008 | 05:41 PM
Zacreth's Avatar
Zacreth
Z Rocker
HKS has the plugs you want btw....
