dilemma 4.083 gears or stock gearing
Old Jun 27, 2008 | 12:12 AM
350Zimo's Avatar
350Zimo
Default dilemma 4.083 gears or stock gearing
As you guys know i am about to get done modding my car . Therefore, i need to take care for one last thing and this is the long stock gearing. As some of you know with the technosquare reflash the redline is 8k and i think short gears would be really beneficial. However, i am kinda hesitant about it, but i want it. SO , i need opinions, and preferably encouraging opinions
should i do it or not
Old Jun 27, 2008 | 04:04 AM
Gooey's Avatar
Gooey
Do It
Old Jun 27, 2008 | 04:23 AM
savvy's Avatar
savvy
What are you hesitant about? If you are worried about the higher RPM at highway cruising speed, you can also look at the 3.9's too.
Old Jun 27, 2008 | 06:06 AM
07Z FoSho's Avatar
07Z FoSho
i will sell you my 3.9 set... only has 1000 miles on it.
it really makes the car pull much harder, i love it.... but im going tt here in the next month or two so im going back to the 3.5...
Old Jun 27, 2008 | 08:48 AM
350Zimo's Avatar
350Zimo
pm me with a price please
Old Jun 27, 2008 | 09:14 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
I really like the 3.91's in my car. Shorter, but not too short.
Old Jun 27, 2008 | 09:18 AM
350Zimo's Avatar
350Zimo
what rpms does your car run at 60mph?
Old Jun 27, 2008 | 09:20 AM
350Zimo's Avatar
350Zimo
do have any in stock?
Old Jun 27, 2008 | 09:21 AM
07Z FoSho's Avatar
07Z FoSho
in 6th? i will look an the way home.... i know 80mph its a hair over 3k
Old Jun 27, 2008 | 09:32 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
I believe 60 is around 2300rpms. It's pretty much a 10% change.
60 goes from 2100-2300ish
80 goes from 2800-3100ish
100 goes from 3500-3850ish
etc...
and yes, I keep a few sets in stock.
Old Jun 27, 2008 | 10:33 AM
350Zimo's Avatar
350Zimo
etc...
so what's better the 4.083 or 3.9
is it not 10% a really subtle increase that is not going to improve anything??
Old Jun 27, 2008 | 10:37 AM
350Zimo's Avatar
350Zimo
etc...
do you know how the 4.083 goes??
Old Jun 27, 2008 | 10:55 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
The 4.08 gears should be about a 14-15% or so change over the stock 3.53 gears?
All assume stock size tire and cruising in 6th gear.
Order is... 3.35(5AT)-3.53(6MT)-3.91(Cen20)-4.08(Nissan)
60 goes from 2000 - 2100 - 2330 - 2430
80 goes from 2660 - 2800 - 3110 - 3250
100 goes from 3330 - 3500- 3890 - 4060
etc...
I believe those are pretty close. If anyone wants to verify my numbers, it wouldn't bother me at all.
Old Jun 27, 2008 | 11:08 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
Here's some other numbers...
Approx maximum speed (mph) in each gear. Assuming stock size tires and 7500rpm redline.
3.53 gears - 3.91 gears - 4.08 gears
1st - 44 - 40 - 38
2nd - 72 - 65 - 63
3rd - 104 - 94 - 90
4th - 133 - 120 - 115
5th - 169 - 152 - 146
6th - 212 - 192 - 184
Once again, feel free to verify these numbers, my calculator may be off a bit?
Old Jun 27, 2008 | 01:54 PM
07pearlwhiteZ's Avatar
07pearlwhiteZ
I have nothing bad at all to say about going to the shorter gearing. I was slightly worried about the cruising RPM's as well, so I went with the 3.9's. It definitely pulls harder. I have actually noticed a slight improvement with city mileage, I think partially because you can drive at a little bit lower RPM's and it won't bog down at all if you have to speed up. The highway mileage does suffer very slightly, but only by like 2 mpg. Nothing that maybe cruising 5mph slower wouldn't get right back. Sorry for the slightly lengthy post, but I just did this mod a little over a week ago, and I love it.
Old Jul 16, 2008 | 06:07 AM
kramykram's Avatar
kramykram
I changed my whole pumpkin out of my 03 with my 4.083 and cusco lsd. all i can say is wow. the car pulls so hard. can't wait to get hfc's or test pipes and a ecu flash.
Old Jul 16, 2008 | 09:25 AM
sharaabi's Avatar
sharaabi
question, does this effect gas mileage?
this past month i was a little broke and did 90% highway driving at 55-60mph and got 420miles before the dte starting flashing showing i have 50miles left.
Old Jul 16, 2008 | 09:33 AM
Hoooper's Avatar
Hoooper
yes it will, but not really that much. IIRC, youll be doing around 3k at 80 mph, but at 55-60 you would still get about the same mileage as stock gearing going 70
Old Jul 16, 2008 | 10:50 AM
kramykram's Avatar
kramykram
im still on my first tank my dealer gave me im at a 1/4 now at about 380 miles. the only time i really notice a differnce is if i stomp it a little. but im still waiting till my motor is broke in to really try it out.
Old Jul 16, 2008 | 02:59 PM
singh's Avatar
singh
_______________
I would stay stock, but that's just me. If you do change, without a doubt, you will consume more gas. To what extent is the question.
Stock gearing is fine, I am not trying to be an all out performance gear head, I think there are other ways to make better power. (Nitrous)
