I've already had the clutch recall done, but.....
I completely lost pressure at the track tonight. Went to launch at about 4k, and the pedal fell on the floor and I ran a really awesome 19 sec 1/4 mile. Anyways, I did probably a dozen runs tonight and it only did it once, but as soon as I was done with the run it was perfectly normal other than smelling like burnt clutch. Is there anything I can do with the dealership, or is there a different fluid or something I should try? It was a hot night and I did a lot of runs, but still it was perfectly fine before and after that run. Any suggestions at all? I did a little searching so far, but all I'm seeing is the initial recall issue.
Originally Posted by kramykram
go ahead and replace your clutch line with a stainless line. sounds like it heated up. i might be wrong but it can't hurt since the line only cost like 30 bucks
after I got the recall done, I did 5-6 3k launches and my clutch felt soft afterwards.. Couple WOT runs too but ya, the clutch fix isn't guaranteed. Helps, but not perfect. Before I'd get a soft clutch just sitting in traffic though.
