Can't Remove Stock Cats. Help!
Old Sep 23, 2008 | 06:38 AM
  #41
fstrnldr's Avatar
fstrnldr
no its not threaded if you break the bolt, or cut it off, it will slip right out.
and just out of curiosity GTM said they couldn't remove it? or was there a time issues ... couple of posts seem to have conflicting info.
Old Sep 23, 2008 | 09:45 PM
  #42
infinite's Avatar
infinite
they said the bolt is stripping, and they'll have to remove the headers and keep the car overnight and that it will cost me much more than the $163 they quoted me.
I figured that they can get the job done, at the price they said... but I guess they couldn't hack it.
They worked on my car for 2 hours
Old Sep 24, 2008 | 11:31 PM
  #43
aloh's Avatar
aloh
oh man...stock cat drama...
Ive been there. Baad horror story too.
Old Sep 25, 2008 | 03:52 PM
  #44
infinite's Avatar
infinite
how did yours end?
Old Sep 27, 2008 | 10:13 AM
  #45
infinite's Avatar
infinite
Doing these yourself is a real PITA... I wish I had a lift
Old Sep 27, 2008 | 02:32 PM
  #46
A.H's Avatar
A.H
Originally Posted by infinite
how did yours end?
He ended up keeping his stock cats on with one broken bolt if i remember correctly
Old Sep 27, 2008 | 04:12 PM
  #47
infinite's Avatar
infinite
UPDATE!.... FINALLY GOT THE JOB DONE, TOOK A LONG TIME BUT I FINALLY GOT THEM ON
Old Sep 28, 2008 | 12:04 AM
  #48
chazz0812's Avatar
chazz0812
More to the point - is anyone really gaining enough Hp or torque to warrant the trouble?
I read a "Dummies Book" on car mods where the author stated that modern cats are pretty good flowing, ie flowing well enough that removing them is not really worth the effort. He said in the 70's and 80's it made a difference, but not now. Everyone has this issue w/our cats. It is really worth the trouble for what HF cats may give?
Old Oct 14, 2008 | 12:13 PM
  #49
RRMikey's Avatar
RRMikey
OP, how did you finally do it? I was thinking about getting test pipes but I had the same thought as chazz0812. I mean do you really feel a difference on a HR with test pipes?
Old Oct 14, 2008 | 02:18 PM
  #50
shadykilla717's Avatar
shadykilla717
U need to spray them with a type of lub. And then heat them. That loosens them alot. I did that and took 20 mins.. And yes you notice a difference with test pipes. I have them on my Z. I love them.
Old Oct 14, 2008 | 03:17 PM
  #51
KS0385's Avatar
KS0385
Is this going to be as tough for me on my 08 as with the 07's?
Old Oct 14, 2008 | 03:56 PM
  #52
infinite's Avatar
infinite
yes I got it done, the one bolt on the driver side next to the steering shaft caused me a lot of trouble, it broke 1 rachet, and 1 extension. I had to use a die grinder to grind the head off and the cat dropped like a rock.
Old Oct 14, 2008 | 03:57 PM
  #53
infinite's Avatar
infinite
07-08's both have the same engine and the same troubles
Old Oct 14, 2008 | 04:01 PM
  #54
4drmadness's Avatar
4drmadness
hey man are you selling ur HR Pipe
Old Oct 14, 2008 | 05:50 PM
  #55
KS0385's Avatar
KS0385
I know that. The thing I am wondering is if it will be easier to do on a newer car because of the length of time that bolt has been sitting there. Or did they use Loctite at the factory on those bolts?
Old Oct 14, 2008 | 05:57 PM
  #56
infinite's Avatar
infinite
it won't make a difference, there's been people with only 250 miles and it was the same issue. My car had 15k miles on it and it wouldn't move.
Old Oct 14, 2008 | 06:07 PM
  #57
KS0385's Avatar
KS0385
Damn that sucks. Thanks for the info.
Old Oct 14, 2008 | 08:42 PM
  #58
infinite's Avatar
infinite
I would of got the bolt off, but I took it to mechanic shops and they stripped it. I think you'd have better luck doing it yourself, using pb blaster, some extensions, 14mm socket and a breaker bar
Old Oct 15, 2008 | 01:44 PM
  #59
KS0385's Avatar
KS0385
What about some Vice Grips instead of the socket wrench?
Old Oct 15, 2008 | 10:15 PM
  #60
infinite's Avatar
infinite
it can't be reached with vice grips.
