Can't Remove Stock Cats. Help!
Old Oct 16, 2008 | 10:07 AM
  #61
hellsoldiers08's Avatar
hellsoldiers08
ya the place i took it to, had to use a blow torch and even that one didnt do it. So they went out of there way and bought a new torching system and sapposely they got it off with that. It just really pushes my buttons that nissan has to make that dam bolt so tight. Its not like it goign to really come loose and if it does i think the person would like the sound either way
Old Oct 16, 2008 | 01:06 PM
  #62
KS0385's Avatar
KS0385
I want to replace my exhaust myself. Cats and Exhaust. No headers. Am I going to be able to do this without a lift by myself?
Old Oct 16, 2008 | 02:41 PM
  #63
whoopazz1's Avatar
whoopazz1
^^^ Yes, it can be done, as long as you have lots of patience, WD40 and jackstands... From what it sounds like, I would soad the **** out of every bolt that you're planning on removing...
I swapped out my exhaust on my 07 and I'v done cats on my 03, so its possible... some will be easier than others.
Old Oct 16, 2008 | 02:42 PM
  #64
infinite's Avatar
infinite
I did.
Old Oct 16, 2008 | 05:21 PM
  #65
KS0385's Avatar
KS0385
Okay, I talked to my buddy and he suggested a couple of things. Use ramps instead of jack stands. And use a Nut Splitter. Next question. Will the nut splitter fit?
Old Jan 18, 2009 | 10:27 AM
  #66
ZPHILE's Avatar
ZPHILE
Default Just adding my .02
Just finished this on my '08 ZR. Here's what I encountered: 1)Scared of PB blaster (shows it eating a cup up on the can!) - this stuff can eat plastics. Used Liquid Wrench Penetrating Oil on nuts/bolts before using breaker bar (a must have). Yeah, it's about 2'. This method worked great 2) That stubborn top cat nut! Moved it w/the breaker bar "broke-it" then when using regular ratchet it laughed at me! Using many extensions from the front and regular ratchet, the bolt just broke off! Luckly, it doesn't thread in the header, just the cat and when it breaks, you're done. Both sides did the same. G/L on this. Now, I have the get that broken piece out in order to use the stock cats again.
H.
Old Jan 19, 2009 | 12:39 AM
  #67
Berk_Technology's Avatar
Berk_Technology
AN IMPORTANT WARNING TO THOSE OF WHO WILL GET THESE INSTALLED.
BE WEARY OF USING IMPACT GUNS ON THAT TOP BOLT. The shock of the impact gun can break the primary O2 sensor. I prefer to use a breaker bar from the top. Remove the intakes and use a long extension and U-joint to get to the bolt.
I have never had to remove the header to get that bolt off. If you must break the head of the bolt off, remove the O2 sensor first before using your chisel.
Old Jan 20, 2009 | 03:21 PM
  #68
Sergio8A's Avatar
Sergio8A
Just Disconnect them first and ur good.....
Old Jan 20, 2009 | 03:24 PM
  #69
mclovin.too's Avatar
mclovin.too
Cut the bolt off and be done with it?
Old Jan 20, 2009 | 05:35 PM
  #70
infinite's Avatar
infinite
I tried breaking the bolt off, and it broke 1 rachet, 2 extensions, and stripped a socket, before being stripped itself. Thats when I had to grind the bolt down with a die grinder. Took a good while, but it done the job. I had to squeeze my hand behind the intake manifold.
Old Jan 20, 2009 | 06:50 PM
  #71
Peak350's Avatar
Peak350
Jesus, this sounds like a lot of effort that I wouldn't expect
Old Jan 20, 2009 | 07:40 PM
  #72
singh's Avatar
singh
_______________
I took my car to a shop full of asians and they got the bolts off in minutes.
..through the engine bay, they used a long extension with a breaker bar..
Old Jan 21, 2009 | 01:03 PM
  #73
Sergio8A's Avatar
Sergio8A
^^^How Many Asians does it take to unscrew a bolt?? lol
Old Jan 21, 2009 | 05:54 PM
  #74
fstrnldr's Avatar
fstrnldr
there seems to be an occasional issue w/ these .... some come right out w/ out much effort, and well others will make you get a bit creative w/ them! Same w/ the o2 sensors .... i've had one stick in a cat and not want to move, every other one has come right out for me, but i've seen a few posts about this on this board as well.
Old Jan 22, 2009 | 09:58 AM
  #75
Peak350's Avatar
Peak350
I've heard from a lot of people locally now since asking that they just shear the head off the top bolt and replace it.
Old Oct 20, 2015 | 08:15 PM
  #76
pwice's Avatar
pwice
In the same boat as the OP, how do you fit a grinder down there on that last bolt to grind it off? I have one bolt left on the driver side, the top one. I've cut the cat off from the cat flange and headers. I'd like to grind the head but not sure how to go about doing so
sales@czp
Sep 23, 2019 03:30 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Depravity
Oct 1, 2015 04:49 PM
