burnt my clutch bad
Old Sep 30, 2008 | 02:18 AM
jmaestre23's Avatar
jmaestre23
Default burnt my clutch bad
ok so before i get flamed for what i did i just wantted to explain what happened and would like to know the outcome of my mistake.....at the track i was probably ran about 7 times....very few people at the track so i was running frequently...i had MT ET streets so i had to warm up my tires......well my last run i decided to warm them up and a little bit more and launch a little higher.....i did multiple burntouts to get them warm...and i launched my car at 5k with a little slip( was having success at 4500 K launches).....the car went but then soon the clutched stuck to the ground and before i knew it was full throttle revving my car 5500-6000 burning the clutch for a good few seconds....i drove home fine the pressure in the clutch is fine it is grabbing normal....so my question is what should i expect from my mistake? advice is more needed than opinions thanks in advanced
Old Sep 30, 2008 | 07:05 AM
kramykram's Avatar
kramykram
i would not worry about it right now, im sure you burnt it good but probably a lot of life left it in. since the 07's have a problem with the pedal stick to the floor. i would contact the deal about replacement of the slave cylinder
Old Sep 30, 2008 | 08:46 AM
jmaestre23's Avatar
jmaestre23
i already replaced it......it happened once before where i had the brake light fuse out and i was trying to do a break stand lol
Old Sep 30, 2008 | 03:07 PM
There's no way to tell about potential clutch damage unless you look at the clutch.
Drag racing breaks stuff.
Old Sep 30, 2008 | 03:10 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
+1. I dont do it no more. New tranny clutch and flywheel and wasnt covered in my warranty
Old Sep 30, 2008 | 03:15 PM
Did you get a chance to post time slips?
Old Sep 30, 2008 | 04:56 PM
singh's Avatar
singh
_______________
Post the time-slips?
The pedal getting stuck to the floor also happened to me the last time I went to the track (which was back in December). I got it replaced but never got a chance to go back to the track to see if the new slave cylinder did anything.
Old Sep 30, 2008 | 10:29 PM
NISMO_558's Avatar
NISMO_558
The same thing happened to my '04, and I had it pegged for atleast 5 seconds or so and I didn't realize what was happening. It was the stock clutch and it had 26K miles and still grabbed fairly well, so it should be fine.
Old Oct 3, 2008 | 08:22 AM
SPRSLO's Avatar
SPRSLO
When you say you did multiple burnouts, do you mean stopped and started multiple times or just multiple revolutions? A couple of revolutions to get the water and debris off is plenty to warm up ETs. If you're having to do John Force burnouts just to get traction w/274 hp, then you need to work on tire pressure.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
