My 1/8 drag race against a lightning!
I did some drag racing tonight out in Irwindale's race track. This is my very 1st time actually drag racing my car! I just had trouble getting a grip tonight at the line, no matter what I did, I couldn't get traction worth a crap I kept my stock tires at 35PSI cold, that could of been part of the problem along not knowing how to launch my own car from a dig. I do have a video of me racing a Lightning (supercharged).
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/4671SWY8BlU&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/4671SWY8BlU&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
My times for that race.
R/T: .621
60': 2.104
330: 5.739
1/8: 8.68
MPH: 82.75
I also raced a 07 WRX STI. I'll post that video later today.
R/T: .621
60': 2.104
330: 5.739
1/8: 8.68
MPH: 82.75
Thanks guys.
Here's the other video.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/YuSa8IdaTkM&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/YuSa8IdaTkM&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
07 350Z Vs. 07 WRX Sti.
The key is the launch. I had stock tires, with 23,000 miles of wear. I had trouble hooking, but my car had to power to pull through with good trap speed. I'm sure with better tires and a clean launch it will be very low 8's and traps of high 80's. I've seen a SRT8 Charger run a 8.66.
That STI race was my very 1st. He got me on the launch but I beat him in the finish.
Damn that old man...Damn I wanted to cuff his azz up
lol j/k...Just when the Z was pulling in the STi, bam, geezer time and his facial expressions
..Im going to hell..Nice runs man..though the lightening would have given you more trouble....
There is no ideal or should be running time. It is what it is. So get out there and give it a try.
. . .but you have to come to Louisiana to get it then take me back with you. . .! I'm runnin 13.7 stock in hot *** weather down here so you should do much better. . .
Great time bro. Can't wait for you to hit up the 1/4 next with possibly some better tires and you shoudl have an awsome time
EDIT: Just outta curiousity, what RPM were you shifting at. I've read multiple theories on when to shift with our 8000K redline.
Thanks...I just let the car shift itself, I don't use the triptronic. I don't know if it will make the performance better or not. Anyone know?
My peak HP is at 6,900RPM. I don't know if it's better to shift at that point, due to gear and speed or if we should stay in higher HP's longer. Stall speed might play a factor as well. I mean I don't know if finishing the gear in at a higher rpm helps you begin at a higher RPM on the next gear or not.
I didn't use triptronic as I'm afraid to redline my engine in 1st due to wheel slip.
hopefully someone chimes in
