Berk HFC's installed I have a ?
Old Feb 23, 2009 | 03:25 PM
  #41
quidproquo's Avatar
quidproquo
Need a Tune!!!
Originally Posted by BADASSTT
It' suppose to do that when your VDC kicks on.
I realize that, but there was no cause for the slippage at the time the sputtering happened. Not to mention when I turn the VDC off, no more sputtering.
Old Feb 23, 2009 | 03:55 PM
  #42
SoCal Piliguy's Avatar
SoCal Piliguy
Originally Posted by Berk_Technology
You do not need a reflash in order to run with TP's or HFC's. The ECU will adapt to the new learned fuel trim value over time. A reflash would help and would optimize the ECU fuel/timing to the HFC's, but it's not absolutely neccesarry.
The secondary O2 sensors do not have any effect on the performance of the car. Even if you smashed them and reinserted them into the BERK HFC's, there would be no performance difference. The secondary O2 sensors are soley there for catalyst efficiency monitoring, that is it.
Can you give us some more details on the conditions when it happens? And anyone else here who has the same type of symptoms? Let's all see if we can solve this together.
Brian,
Any idea on a fix for the hesitation / sputttering? I'm on the verge of going back to running stock cats. I can no longer stand this performance issue.
Please help.
Old Feb 23, 2009 | 04:36 PM
  #43
BlueZ33's Avatar
BlueZ33
if your looking to get rid of them ill take them off of your hands
Old Feb 23, 2009 | 07:03 PM
  #44
jason350z's Avatar
jason350z
Sounds about right. Thanks
dude i have the same problem your having!! today on my way to work i got an engine check light. i have berk cats and other **** then got a reflash. after that i got the injen intakes. i took my exhasut off anf i'm waiting for another one. gona go to autozone so they tell me what the light code it is
Old Feb 23, 2009 | 07:18 PM
  #45
kramykram's Avatar
kramykram
jason350z, reset your ecu. then let your car warm up to normal levels before you drive. then see if the cel comes on. or put some brillo stuffing in the hole before the 02 sensor.
Old Feb 23, 2009 | 07:21 PM
  #46
SoCal Piliguy
Make me an offer i cant resist. By the way they're off a 2007 G35S sedan. Please confirm fitment.
Old Feb 23, 2009 | 07:23 PM
  #47
SoCal Piliguy
NO CEL since day one.
Just the sputtering and hesitation. It seems to be hit and miss. Some cars don't have this issue with the same setup. What's wrong with ours?
Old Feb 23, 2009 | 07:40 PM
  #48
kramykram's Avatar
kramykram
i wish i knew. if i had more hr's here to work with it wouldn't be so bad. but those that have changed out around here have not had problems at all. i only had the problem when my cel was on. but since you are having it without a cel i would put the stock cats back on and see if it still does it. if it does then warranty will resolve the problem.
Old Feb 23, 2009 | 08:18 PM
  #49
kramykram's Avatar
kramykram
the shop i used to work at has a scan tool but ill be damned if i can remember what it is i borrow off top of my head. but it data logs. since the problem is not happening with our cars here i can't log any of the issues to see exactly what it might be.
Old Feb 23, 2009 | 08:22 PM
  #50
jason350z's Avatar
jason350z
ok this is what i have/had. i had the fast intensions intimidator exhasut, with berk metallic HFC, then i got a reflash by technosquare. i dont remember if i had the problem then. later on after the reflash i got injen dual intakes. then i sold my fast intensions exhasut and i have the stock exhaust on now.
i guess this is when i notice the problem in 6th gear if i'm rolling at 2000 its fine but if i press the gas pedal hard to pass a car or what ever then the car jerks. but i had never had a cell light and i've had the cats for like 4months. drove with them for like 3,000 miles.
now today it was a quick start and after like 10 miles of driving the engine light went on.
so i dont know man
Old Feb 24, 2009 | 05:10 AM
  #51
jason350z's Avatar
jason350z
ok went to autozone after work. the code i was geting was po3 p002 something like that anyways it said it was HFC. i dont know i drove like 2-3k miles never had a light. the only thing was that yesterday i didn't let the car warm up.
Old Feb 24, 2009 | 06:11 AM
  #52
singh's Avatar
singh
_______________
^ can you recall the exact code? Look in here to match it with an error code..
https://my350z.com/forum/engine-and-...y-helpful.html
Old Feb 24, 2009 | 06:27 AM
  #53
jason350z's Avatar
jason350z
yeah i wrote them down they were p0420 and p0430 according to the list u showed me they are this:
P0420 TW (Two-Way) Catalyst System, Bank 1
P0430 TW Catalyst System, Bank 2
Old Feb 24, 2009 | 10:24 AM
  #54
singh's Avatar
singh
_______________
yea that's the same code I got a few days ago. It's nothing serious..
It came up because I was keeping my car in high rpm's for a long period of time..ever since I reset the ecu and I have driven about 350 miles and it has not come back on..
Old Feb 24, 2009 | 01:39 PM
  #55
jason350z's Avatar
jason350z
i know but its annoying and i'm sure it will come back.
the only possitive thing about this was that i learned how to check the codes it was too easy and free. damn dealers try to charge me once 100 bucks to run diagnostics on my daily driver hyundai accent.
Old Feb 25, 2009 | 09:57 PM
  #56
BADASSTT's Avatar
BADASSTT
well so far so good. I have'nt had any bogging issues. But I dont know? I feel that when the car is at low rpm's and I floor it underload it seems slower until my RPM's go over 3500 or it's just me?
Old Feb 26, 2009 | 12:00 AM
  #57
markk132's Avatar
markk132
autozone will read your CEL codes for free???
Old Mar 6, 2009 | 07:06 PM
  #58
jason350z's Avatar
jason350z
they gave me the mashine to read it my self. its so easy man.
update about the hesitation when driving in 6th gear and tring to accelerate quickly.
well i bought a borla exhaust and installed it today and the hesitation is gone. i think its because my ecu was reflashed/tune for a dual exhaust and i recently i had reinstalled the stock exhaust. maybe that caused it i dont know but now that i have a higher flow exhaust its gone.
Old Mar 7, 2009 | 12:43 PM
  #59
itsjiggajames's Avatar
itsjiggajames
I've had the berks HFC as well as other members on there HR and most if not all get the stuttering around 2500-3k rpms in high gear and WOT.. Hopefully this lean nature of the HFCs installed does not create long term wear on the motor.
Old Mar 26, 2009 | 10:39 AM
  #60
JWS82's Avatar
JWS82
Any updates on fixes? I just ordered my Berk HFCs yesterday and after reading about all these issues.. am starting to second guess my decision. Quite paranoid now actually..
