Berk HFC's installed I have a ?
Old Feb 17, 2009 | 04:03 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by Berk_Technology
Solo - Good info there. So were you getting a lean spike during transient thorttle situtations under very high load?
From what you guys are saying, this only happens in higher gears @ low RPM (high load).
I haven't received my graph yet from UPREV, but he said I was running pretty lean due to the cats now.
Taking off in 1st it happened to me a lot because of the load and the gear. They even had it happen to them on the dyno engaging first.
Old Feb 17, 2009 | 04:04 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by SoCal Piliguy
Agree with you 100%. I have the Berk HFC's on my 07 G35S sedan. I've experienced the same hesitation, sputtering and lack of power below 3k rpms since day one. Performance issues still present after a TS reflash. I am seriously considering running my stock cats. There was another member on the G35Driver boards that had the same issue. Evidently he went back to stock cats which remedied the problem.
If you can get yours custom tuned not just a flash from TS, that would fix your problem. You just need to get your A/F adjusted.
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
What specific details do you need. I'm willing to help figure out the fix for this issues. Perhaps you would also need input from the tuners as well. Hence TS would have to be involved also. I'll give you a call tomorrow.
I don't believe they will be able to fix their problem with the cats. It's just the way the car reacts to HFCs or Test Pipes.
Old Feb 17, 2009 | 06:06 AM
SoCal Piliguy's Avatar
SoCal Piliguy
TS actually custom tuned the car. A/F was adjusted as it was seriously running lean.
Old Feb 17, 2009 | 06:20 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Then you shouldn't be having the issue. Strange. What is your A/F on the graph? Around 12.5-13.5?
Old Feb 17, 2009 | 10:49 AM
BADASSTT's Avatar
BADASSTT
Does this go for me too? How do I go about getting a custom tune? If I would have known the HFC's do this I would have not bought them. I wonder if there are others having this issue running HFC's or TP's?
Old Feb 17, 2009 | 11:52 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Yea I had no idea either till I got them. Now that we mention the problem it seems others have it too. LOL!
It would be worse with TP's.
Many tuners here can tune your car. You can find a tuner in your area that does UPREV or Technosquare and have it custom tuned on the dyno to fix your A/F that should solve the problem. But someone here said their Technosquare didn't so maybe UPREV is better in this area as it is adjusting the stock ECU itself and not a piggyback.
Old Feb 17, 2009 | 01:50 PM
Sergio8A's Avatar
Sergio8A
will i have any problems in the long run for the car runnin LEAN?
Old Feb 17, 2009 | 02:04 PM
BADASSTT's Avatar
BADASSTT
Well I guess I'll have to go for the UPREV. Damm more money down the drain. I was going to stop for a while on my HR because, I have a 1982 280zx Turbo
that I just completed restoring and upgrading and that pretty much sucked me bone dry.But I gotta do what I gotta do it's just going to have to wait.The wife is going to have a **** fit.
Old Feb 21, 2009 | 11:49 AM
BADASSTT's Avatar
BADASSTT
Car is running good now Problem has resolved on it's own.
Old Feb 21, 2009 | 05:28 PM
SoCal Piliguy
WHAT are you serious?
You didn't do anything to fix the problem?
Congratulations! I've been suffering since I installed the HFC's.
Old Feb 21, 2009 | 07:35 PM
Sergio8A's Avatar
Sergio8A
how
Old Feb 21, 2009 | 08:43 PM
JasonLee07's Avatar
JasonLee07
I have the Berk HFC's and I'm also experiencing the hesitation problem. I was going to get the TS reflash in hopes that it would fix the problem, but that doesn't seem to be the case.
I'm not sure where I can get a custom tune in my area (Pittsburgh, PA). Are there any other options?
Old Feb 21, 2009 | 09:11 PM
singh's Avatar
singh
_______________
I only had the car hesitate on me once out of the entire 8 months that I have owned Berk HFCs..
Well if I recall Berk have upgraded their HFCs..i believe they increased their diameter to 2.5" now..
I have the 2.25" HFCs and I have no hesitation problems. I know this may make no sense but maybe it's the 2.5" diameter on the new HFCs that may be the cause..
Old Feb 22, 2009 | 05:08 AM
SoCal Piliguy
FYI... Technosquare was unable to remedy the problem even with a custom tune. My plan is to install my stock cats back on unless someone figures out a fix soon.
Old Feb 22, 2009 | 08:28 AM
BADASSTT's Avatar
BADASSTT
Originally Posted by Sergio8A
how
Dont know? Just drove the car and like 2 weeks later it was gone.
Old Feb 22, 2009 | 08:29 AM
BADASSTT's Avatar
BADASSTT
Yeah, I have the new 2.25 HFC's.
Old Feb 22, 2009 | 08:37 AM
  #38
0jiggy0's Avatar
0jiggy0
I honestly dont notice it in 1st or 2nd because they go by so fast. But 3rd gear like I said before, around 2k and do a stomp and mine was pretty bad. I never resseted my ecu because I was told it would learn on its own and wasnt required. Dunno if thats the case
Old Feb 22, 2009 | 09:55 AM
  #39
quidproquo's Avatar
quidproquo
Need a Tune!!!
I don't have the Berk HFCs, but I get this sputtering also. Has anyone noticed their limited "slip" light on the dash fluttering on and off at the same time?
Old Feb 23, 2009 | 01:26 PM
  #40
BADASSTT's Avatar
BADASSTT
It' suppose to do that when your VDC kicks on.
