I want to see a single turbo kit still. save a grand or more for nearly the same performance as a tt setup. yes please! That grand can go toward rods/pistons
Theres been some research done on oval ports vs square ports, and square ports don't begin to perform better than their oval counterparts until some radical amount of lift (greater than 14mm).
As for the lower manifold and runners, I'd imagine the square runners are strictly for increased cross sectional area, while occupying the same amount of metal/space.
TK
Right, saw a lot of research in pushrod motors regarding square vs round port and round port almost always won for power production.
But again, all I can imagine for the runners being square, was that it was a spacing issue inside the manifold and square allowed for more area (or the same area) in less space, but that makes for a power compromise I'd think.
I also note we said the same thing
I wouldn't doubt there's a bit of a power compromise, but given the space constraints, it must have been the lesser of 2 evils. Since we seem to be on the same page, the question that bothers me about the HR, is what it's truly capable of with a set of cams more aggressive than the 248s and some tuned length headers.
TK
I don't like messing with cams on cars with continuously variable cam timing too much, 248's are decently aggressive for a street cam, and if you play with the opening too much, you end up exceeding the adjustment range of the system as a whole.
It doesn't compromise power production, but it can really compromise your idle.
5 psi is weaksauce A.H. Go big or go home lol. Besides u know you'll be addicted top boost and def wanna turn it up!! I always drive on high boost .
I'll stay home
5psi is weak which is why I would need an engine build and let's just say I don't have dumptrucks full of cash like you do to go through an engine build and two sets of twins
+1. Besides 5 psi should be enough to give u some decent power in a HR.
Hey A.H. weren't you supposed to get the manifold about a week or two ago? I think I remember reading a post about that. I might be wrong though and I don't feel like reading for an hour to check so I figured I would ask instead.
Revshift was rushing to have it ready by HIN so I could have it on display cause I was showing my car. However, they didn't make that deadline. I should be getting it soon but to be honest I don't know any more than you guys. I've been waiting as well. Only thing that I know for sure is that pics will come before dynos
We're talking like 3 weeks ago. They probly dynoed the thing and saw no gains. Rev was all over this thread till the time came to show. O well, hopefully someone comes up with something.
We are still here and we have not done anymore dyno testing yet. We are continually working on the manifold. There have been a few minor changes made, we are trying to make it perform successfully in one try. It is still on the way, we will post the pictures before the dyno results. Again, we will not give up until we produce a manifold that makes significant power.
