Transmission noise
Old Mar 26, 2009 | 06:50 PM
Fatitude's Avatar
Fatitude
Default Transmission noise
Hey all I have an 08 mt6 roadster that just hit 6k miles. In the last week or so I noticed an abnormal noise comming from the transmission at idle. With the clutch depressed the noise goes away, but let go and it comes back. Sometimes it is far louder than others. I have an appointment with local dealership to take a look, but I was wondering if this is a common or rare occurance. I see the 07's have some tranny probs but didnt see anything for the 08's. Just wondering if anyone had any insight if this normal after breakin period( I completely babied her thus far)?
Thanks all for any assistance.
Old Mar 26, 2009 | 07:01 PM
freedonutss's Avatar
freedonutss
Perfectly normal. Its flywheel chatter. When you have the clutch in the noise is gone but when the clutch is out (neutral) it sounds like a cement grinder type of noise. Probably louder in a garage or beside a wall. Hope this helps!
Old Mar 26, 2009 | 07:06 PM
Fatitude's Avatar
Fatitude
wow thanks free. Actually funny enough I first noticed it pulling into my extremely small garage, I was terrified at the noise. Should I still take her to the dealership for a look see just to be safe(already took the day off and it is still under warranty?) Thanks again!
Old Mar 26, 2009 | 07:10 PM
freedonutss
They will tell you its normal. Dont waste a trip to the dealership unless your noticing other transmission problems.
Old Mar 27, 2009 | 03:02 AM
Gilles1961's Avatar
Gilles1961
Also my 350 my07 sound similar a diesel car in idle
But i don't care
Old Mar 27, 2009 | 05:41 AM
Nismo 78's Avatar
Nismo 78
Mine does the same exact thing, even after 11.5k It does seem annoying at first but you just get used to it. Totally normal
Old Mar 27, 2009 | 11:52 AM
nismology1's Avatar
nismology1
That is not flywheel chatter. It's gear lash noise and/or rattle and is completely harmless.
A piston engine's power delivery is not seamless like an electric motor. A piston engine makes pulses of power very rapidly. How often? In the M3, (3 X rpm) per minute. Now realize that any drivetrain component (transmission or differential) has a certain amount of looseness or slack in it - it must, or being too tight would create a lot more friction. So when the power pulse engages the transmission, it is causing the rotational power going through the unit to take up that slack. This effectively causes components to touch that were not pressed together a moment before. Between each power pulse, those components de-couple. Press any two hard objects together, whether it be a tea cup and saucer or a hammer and nail, and you notice that noise is made. Repeat the contact-release-contact cycle quickly and it makes a staccato sound - a rattle.
Old Mar 27, 2009 | 12:18 PM
biggersNISMO's Avatar
biggersNISMO
its normal, like everyone said, its the cluth n flywheel making the noise. don't be alarmed
Old Mar 27, 2009 | 12:24 PM
nismology1's Avatar
nismology1
No, it's the gears in the transmission coupling and decoupling many times per second.
Old Mar 27, 2009 | 01:19 PM
freedonutss
doesnt matter what it is its harmless thats all that matters
Old Mar 27, 2009 | 05:59 PM
biggersNISMO
ha ha, good one "nismology1"
as long as we all know its normal, thats what matters lol
Old Mar 27, 2009 | 08:36 PM
Fatitude's Avatar
Fatitude
Hey all thanks again for the help much appriciated, was honestly close to crapping on my garage floor when I first heard it.
Old Mar 28, 2009 | 01:42 AM
That One Dude's Avatar
That One Dude
I always thought it was the Throw Out Bearing...
I have a 2008 Enthusiast and i hear it too... Flipped me out when i heard it the first time...
Old Mar 28, 2009 | 02:50 AM
dyss's Avatar
dyss
^^^ thats what i thought too. so the dealership replaced mine free of charge and it was still making the noise... got a new bearing though haha.
yea my 07' does the same ish... kinda pisses me off but i've pretty much gotten over it.
Old Mar 29, 2009 | 04:19 PM
wilsons780's Avatar
wilsons780
well folks, i've had the same noise with my 08. i've got 37700 miles now. took it in at 1000 mile again at 5000 then again at 36500. i replaced the throwout asy. when i upgraded the clutch at 32000 miles. the noise got worse over time and finaly they decided to replace the trans on the last visit. the car shifts better and sounds normal again. wondrful
Old Mar 29, 2009 | 05:01 PM
rgdodson54's Avatar
rgdodson54
I have the same noise in my 06 Track. Nissan explained that the Z 6 speed has alot of straight cut gears, thus the noise........completely normal
Old Mar 29, 2009 | 05:08 PM
Slyde77's Avatar
Slyde77
No way man bring it in. I have a 08 touring (500 miles)and my boss has a 08 enth (350 miles). Mine makes noise and whines when i speed up, his doesnt. im calling up tomm to bring it in.
Lance
Old Mar 29, 2009 | 08:04 PM
theKoosh's Avatar
theKoosh
from what a lot of people are describing it sounds like a faulty throwout bearing... but everyone keeps insisting that this is normal. on my RSX tho, i had a lot of noise in neutral with the clutch disengaged, and then the exact same "whining" through the gears that some people described... took it in, turns out there was no fluid in the transmission (badly done fluid flush, didn't torque the drain bolt enough and it popped out) and that's what caused the bearing to fail. so i don't know...
*update* took it to the dealer, they claimed it's because my clutch is wearing out... standing on the throttle in 4th gear doesn't quite agree with that assessment though, and i haven't felt any slippage in the week that i've owned it, but we'll see...
Old Mar 30, 2009 | 11:04 AM
Tac-M's Avatar
Tac-M
every 6 speed z has that chatter. it is normal. my car sounds even worse because of aluminum flywheel...
Old Mar 31, 2009 | 10:06 AM
theKoosh's Avatar
theKoosh
car back, dealer insists it's normal but my clutch is wearing supposedly... oh well, looks like ill be getting a JWT flywheel/clutch combo... haha
