Problem with 1st to 2nd.
Old Nov 22, 2009 | 09:32 AM
Nateclipse's Avatar
Nateclipse
Default Problem with 1st to 2nd.
When i take off in my HR from 1st to 2nd gear, it feels like my clutch stays in sometimes. It kinda feels like it is slipping maybe? I took it to nissan and they drove it around and said it was fine. But i know something is wrong with it. It really doesnt do this all the time, but sometimes its really bad. I cant even burn my tires goin from 1st to 2nd gear mostly. It hesitates too much before it picks back up, and even i will be in 2nd gear sometimes and my car will just rev until i take it out of gear and put back in. I know this might seem kinda confusing, but maybe somebody can help me? Ive thought bout just goin to nissan and buying a new oem clutch, but before i do i just want to make sure and see what yall think. my car has 28k on it and i bought it used at 24k, so i think the owner before me burnt the clutch up. but anyways, any help?
Old Nov 22, 2009 | 09:42 AM
NISMO_558's Avatar
NISMO_558
sounds like a slipping clutch to me
Old Nov 22, 2009 | 10:24 AM
binder's Avatar
binder
sounds like a burnt up clutch but it wouldn't start working after taking it out of gear then then back into gear. It would slip almost all the time and probably would slip in first gear if you gave it gas.
If you hammer the gas in first gear and the rpms go up but the tires don't spin then the clutch is slipping.
Old Nov 22, 2009 | 10:32 AM
Emski's Avatar
Emski
07? slave cylinder.
Old Nov 22, 2009 | 10:45 AM
Nateclipse's Avatar
Nateclipse
it was the later 07, they said the recall was already fixed when my car was made.
Old Nov 22, 2009 | 10:48 AM
Nateclipse's Avatar
Nateclipse
thx, it feels like that may be it. they said the recall on the slave cylinder was already fixed on my 07, so i dont think that is what it is, or i hope not.
Old Nov 22, 2009 | 11:02 AM
binder's Avatar
binder
when the slave cylinder goes out the clutch is engaged and you can't disengage it. Pushing the pedal won't disengage the transmission from teh car so it will just keep driving. That or your pedal will go down and stay down due to loss of pressure.
Old Nov 22, 2009 | 11:17 AM
Did you check the applicable sevice bulletins for your model year?
Old Nov 22, 2009 | 11:28 AM
Nateclipse's Avatar
Nateclipse
yea my pedal doesnt stay down, it pops back up, so i guess this is a slipping clutch, thx alot dude for the help.
yep, everything is up to date when i went to nissan.
Old Nov 22, 2009 | 11:29 AM
Nateclipse's Avatar
Nateclipse
btw, anybody know how much a 07 stock clutch is from nissan off the top of their head?
Old Nov 22, 2009 | 11:36 AM
Well you may have missed this:
NTB08-002
2007 NISSAN 350Z 6MT; VOLUNTARY SERVICE CAMPAIGN CLUTCH SLAVE CYLINDER
Nissan has determined that on some 2007 350Z vehicles equipped with the 6-speed manual transmission, the clutch slave cylinder assembly may not have been manufactured properly. This could result in the operating force of the clutch pedal becoming light, and in some cases, could result in improper clutch operation. Nissan is conducting a Voluntary Service Campaign to replace the clutch slave cylinder assembly with a new improved part
free of charge for parts or labor.
Old Nov 22, 2009 | 11:47 AM
Nateclipse's Avatar
Nateclipse
NTB08-002
yea, i asked about that, he said this issue was with the ealier 07 350zs. mine was a later 07 and he said they fixed the problem before my car was made. so no recall on my csc, but im sure that this isnt the problem tho, my clutch doesnt feel lighter and it isnt sticking to the floor. but thx for the info.
Old Nov 22, 2009 | 12:19 PM
binder's Avatar
binder
just get an aftermarket clutch if you're going to be in there anyways.
Old Nov 22, 2009 | 07:11 PM
Peak350's Avatar
Peak350
Not sure I recommend this. I just bought a stock clutch from Kyle @ Import Parts Pro and it was the cheapest price I'd found.
Stock list is somewhere near $600, he was a fair bit less.
Old Nov 23, 2009 | 05:15 AM
binder's Avatar
binder
well, i was just looking at a good aftermarket clutch for n/a and mild FI is about 400$ so less expensive than OEM. If he plans on ever doing any mods to the car he might as well put a better clutch in. I made that mistake and ended up putting aftermarket in my car in less than 6 months.
Old Nov 23, 2009 | 05:47 AM
Peak350's Avatar
Peak350
I don't mean to sound jaded but I wouldn't have another aftermarket clutch in the 07+ Z's without a stock height/weight pressure plate (or the ats slave conversion). I had a jwt for ~16k miles and I can recommend neither the clutch or flywheel.
I'm not speaking from lack of experience, in heitant to recommend aftermarket clutches after losing 2 slaves 4k and 8k miles each....on the jwt setup.
Old Nov 23, 2009 | 07:00 AM
binder's Avatar
binder
hmm, true. He could use an aftermarket friction plate with stock pressure plate. No increased pressure then now slave cylinder failure.
Old Nov 23, 2009 | 12:10 PM
Nateclipse's Avatar
Nateclipse
$600 for a stock clutch? dang. wish that was under warranty.
Old Nov 23, 2009 | 05:04 PM
Peak350's Avatar
Peak350
I have a used clutch/pressure plate from a junkyard thats pretty rusty but still has some meat on the clutch.
You're welcome to it if you cover shipping (probably like $20). I didn't trust the pressure plate because of the rust, but it came with the flywheel I bought so...
Old Nov 23, 2009 | 05:06 PM
Nateclipse's Avatar
Nateclipse
thx, but with my slipping clutch, it prob messed the pressure plate up too. i would so grab it from you if the pressure plate was ok, but thx tho!
