? how heavy the HR Z should be ?
Old Apr 11, 2010 | 10:37 AM
hellsoldiers08's Avatar
hellsoldiers08
Question ? how heavy the HR Z should be ?
Well this past wed. i went to the drag strip and they had a weigh scale. So i role my car on top of it with me and my friend in the car. I look at the display and i was shocked! 4060lb! So me and him got out of the car and it went down to 3700's ish area. I had 3/4 tank of gas, 2 10"jl w6 subs with custom box. 1 6 channel jl amp and 1 jl 500/1 amp. I was wondering how when they said 3300ish area for the z did they weigh it with gas or not?
yes i did do a search but it was hard thinking of what to type? so i just typed weight and it gave me a pull down of what it thought i was looking for. well the couple i clicked on were post from 2002 area so that didnt really help
Old Apr 11, 2010 | 11:04 AM
MDHRZ's Avatar
MDHRZ
http://www.edmunds.com/used/2007/nis...262/specs.html
Old Apr 11, 2010 | 11:29 AM
hellsoldiers08
Curb Weight: 3339 lbs. Gross Weight: 3919 lbs. hmm not fully answering my question. did they do the weight with gas or not and also i was thinking the scale would be off because last time i was there the car weighted in at 3380/with out me in it and 1/4 tank of gas.
Old Apr 11, 2010 | 11:54 AM
mistanismo's Avatar
mistanismo
Then do the math. Without you and 1/4th tank of gas is pretty close to 3339lbs... so add in approximately 1/4th tank of gas, add in your subs... mods not really much for weight reduction... and you're at 3380lbs.
They weigh them with essentially no gas in the tank, hence curb weight.
Old Apr 11, 2010 | 12:09 PM
hellsoldiers08
so your saying with a full tank of gas the car is around3 to 400 pounds heavier than what is listed hence the curb weight?
Old Apr 11, 2010 | 12:31 PM
blue350zed's Avatar
blue350zed
Actually it should be closer to about 110 pounds heavier, assuming a gallon of gas weighs 6.216 pounds per gallon.
Old Apr 11, 2010 | 12:34 PM
mistanismo's Avatar
mistanismo
Gross is considered to be an 'average' weight... aka including a passenger and potentially some 'luggage'.
Assume a full tank of gas is 120lbs. Assume your passenger is 180lbs. assume you have 'cargo'... easy 325lbs, and there you have gross weight.
Old Apr 11, 2010 | 01:11 PM
MDHRZ's Avatar
MDHRZ
Simple math.
Old Apr 11, 2010 | 01:48 PM
THe correct term is “curb weight.” It has been an ongoing discussion for 7 years.
Old Apr 11, 2010 | 03:39 PM
T_K's Avatar
T_K
Curb weight is measured with all fluids topped off, including gasoline. No passengers and no cargo.
Old Apr 11, 2010 | 04:02 PM
singh's Avatar
singh
_______________
when i was at the drag strip last year my HR without me in it weighed 3,330lbs.
i believe it had a half tank of gas
Old Apr 11, 2010 | 11:44 PM
hellsoldiers08
lol i asked for the flaming on the curb weight lol well see mine with a around 1/4 tank ,no one in it,was last time was around 3380?? so how does that add up to close to 400 pounds more??only changes i have done was y-pipe and intakes :/. also mine is a enthusiast. I guess what im trying to ask is was the scale either off or how did i jump 400lbs?
Old Apr 12, 2010 | 01:23 AM
kramykram's Avatar
kramykram
termites
Old Apr 12, 2010 | 02:52 AM
MDHRZ's Avatar
MDHRZ
^+1
Old Apr 12, 2010 | 07:15 AM
scotts300's Avatar
scotts300
How did your trap speed compare this time to last time when it was "400 pounds lighter"? Stereo equipment can get rather heavy. Those scales are typically calibrated, so that shouldn't be a problem. Did you change wheels? Rotors/brakes? Any body work?
Old Apr 12, 2010 | 07:22 AM
BornSlippyZ's Avatar
BornSlippyZ
+1 Audio equipment weight adds up. Wires/boxes/speakers etc..
Old Apr 12, 2010 | 07:40 AM
scotts300's Avatar
scotts300
Yeah, those big magnets and all.
Old Apr 12, 2010 | 10:33 AM
hellsoldiers08
the audio was in the car last time. I took at the spare out about 2 weeks ago. and during spring break time i got a y-pipe and injen intakes. Theses are the only 2 pieces that have been put on the car and the spare taken out. I was just averaging about 101 and getting a rather consistent time of 14 flat and fastest was a 13.9 @ 98mph. Fyi tracked was horribly prepped that night.
Old Apr 12, 2010 | 12:05 PM
03threefiftyz's Avatar
03threefiftyz
98-101 w/ an bolt-on HR? Pull all that weight out next time.
Old Apr 12, 2010 | 12:30 PM
hellsoldiers08
what weight?? and that because, like i said, the track was horribly prepped. I would spin going into second. Fyi i never spin at that track ever.
also back when i just had test pipes and cat back with the oem 07 rims i did a 13.8 at 104 with spare tire to.
