Custom Intakes
Old Jul 8, 2010 | 09:33 AM
  #41
bardabe's Avatar
bardabe
Originally Posted by stock07g35s
What did you use for the sensor portion of the intake (the black part). Did you cut the factory piece, or is that from another car?
I'm using the Nismo 2.75" R Tune intakes (top half) and made my own Custom extensions for them also in 2.75" The stillens are 2.5" so mine should theoretically flow better and more air. but I found a weak spot on the Greddy X Pipe, so I am in the process of making a better X Pipe before heading back up to the Dyno.
Old Jul 8, 2010 | 10:31 AM
  #42
MDHRZ's Avatar
MDHRZ
Think you could fab up some pipes so I can put my strut bar back on?
Old Jul 8, 2010 | 02:00 PM
  #43
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Originally Posted by jace350z
when i was using the fujita i wrapped mines with 1" header wrap. Plastic tubes would stay cooler though.
Header wrap defeats the purpose. It is designed to retain heat, not repell it. The idea behind header wrap is to keep the heat in the exhaust tubes and not allow it to transfer to the engine bay. A heat deflective wrap would be better for intakes.
350Z_Al
Oct 29, 2020 07:44 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
