Mishimoto Racing Thermostat - not compatible with High Rev?
Old May 23, 2010 | 11:56 AM
NismoZ_840's Avatar
NismoZ_840
Default Mishimoto Racing Thermostat - not compatible with High Rev?
Recently purchased a Mishimoto Racing Thermostat for my 2008. 350z While the site says it works on a 2008 (http://www.mishimoto.com/nissan-350z...mostat-03.html) there is the extra "oil cooler" outlet per 2006 FSM that does not exist on the High Rev OEM thermostat.
Seems strange since an oil cooler isn't stock on 2006 unless they mean the heat exchanger.
Is there some trick to install this on the HR or is it just the wrong part?
Of course I didn't discover this till I spent an hour pulling out the OEM one Lesson learned; check new part against old prior to disassembly...
Old May 23, 2010 | 02:51 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Thermostats are different on an hr
mishi ones are known to have "issues" on a variety of other platforms
what makes you think you need such a part even if it did exist?
Old May 24, 2010 | 07:43 PM
NismoZ_840's Avatar
NismoZ_840
Basically looking for any options to keep coolant/oil temps down at the track. Figured this was a cheap and easy since I was flushing the system of antifreeze and going to water/water wetter. I realize it only delays the inevitable oil temp buildup based on data logging. Spec'ing out oil cooler setups now...
Old Aug 17, 2011 | 02:20 PM
srsairbags's Avatar
srsairbags
just ordered mine from intensepower along with hoses . . it says HR application
Old Aug 17, 2011 | 02:26 PM
srsairbags's Avatar
srsairbags
Angry
fack . . . just found this on the mishimoto website . . .
Note: Thermostat housing does not fit the HR motors (VQ35HR). Thermostat can be removed from supplied 03-06 350Z housing and installed into the OEM 07-08 350Z housing.
but TSM advises against it . . says
CAUTION:
Do not disassemble water inlet and thermostat assembly.
Replace them as a unit, if necessary.
any suggestions guys ? ?
Old Aug 17, 2011 | 07:49 PM
srsairbags's Avatar
srsairbags
anyone ?
Old Aug 18, 2011 | 07:09 AM
srsairbags's Avatar
srsairbags
anyone switched thermostats in the assemblies ? ?
Old Aug 18, 2011 | 09:34 AM
str8dum1's Avatar
str8dum1
how is it going to keep your car cooler? All they do is open a lil faster. Once the car is at operating temp, either the stock or aftermarket is going to be wide open. There is absolutely no difference in cooling at that point.
Return it and get your money back.
Old Aug 18, 2011 | 09:38 AM
srsairbags's Avatar
srsairbags
thanks for replying . . . im just stupid . . was hoping this Tstat stays open for longer than stock . .
Old Sep 6, 2011 | 11:22 AM
FastGreg's Avatar
FastGreg
Originally Posted by srsairbags
CAUTION:
I just planned to buy the Nismo thermostat for the VQ35DE and swap it to the OEM housing, I guess I will surender..
Old Sep 8, 2011 | 06:53 PM
KingBaby's Avatar
KingBaby
Hardest Setting
So does the nismo thermo work with the HR? I have one for about three years now just still collecting dust!
Old Sep 10, 2011 | 08:13 PM
Viksz33's Avatar
Viksz33
PM gamermodz he did one on his hr
SharX59
Sep 27, 2015 09:23 AM
