Weird Idol when cold
Old Aug 18, 2010 | 10:50 AM
hellsoldiers08's Avatar
hellsoldiers08
Default Weird Idol when cold
So when the car has been sitting over night and the next day i go to turn it on, it would make a weird sound at 1.5k and after a sec go up over a tad 2k.
I thought it could be because it been 2 months after i got my intake installed and maybe some dust got int or something. I took it to my mechanic to get the maf sensors cleaned and also did a vacuum test to make sure that couldnt be the problem. Well the problem still continued and so i replaced my spark plugs to finding out there in great condition for 24k but still put in the new ones. I have taken it to uprev,in austin, and they couldnt reproduce the symptoms, even when the car sat for 4 hours while i waited. Im honestly thinking it the tune sense i have tried every psychical thing that could cause the problem.
Well here is the video that i also showed Uprev.(turn up volume and pay attention as soon as i turn it on)
http://www.youtube.com/watch?v=PAfxbwAyi8I
Old Aug 18, 2010 | 12:08 PM
hellsoldiers08
bump anyone ??
Old Aug 18, 2010 | 12:26 PM
winchman's Avatar
winchman
That's almost identical to what my '08 has done since day one. It starts with a quick rise to 1500-1800 rpms, the rpms drop a little as it misses a few times, it picks back up as it starts running smoothly, than gradually drops to normal. I always wait at least 45 seconds before shifting into gear after a cold start. By then it's down to about 1100+/-.
The rpms seem to depend on the ambient temperature, but the pattern is always the same. The dealer says it's normal, and since the car otherwise runs perfectly, I'm not going to worry about it.
Someone else explained that the computer was trying to establish the minimum extra fuel needed to keep the engine running smoothly as it's warming up. Seems reasonable.
Old Aug 18, 2010 | 12:29 PM
angelo350z's Avatar
angelo350z
I really think that's normal Some of my previous cars start at a high RPM when cold.
Old Aug 18, 2010 | 12:36 PM
vex008's Avatar
vex008
dunno if its normal but happens on mine as well.
Old Aug 18, 2010 | 01:12 PM
hellsoldiers08
well funny thing my car use to start "normal" then i got a tune during spring break and a month after it started doing this....Also i changed oil during the time i got the tune, castro synthec. I have another thousand miles before my next oil change(i do it myself) and i hope maybe it the oil(going with amsoil 5w-40 this time)
Old Aug 18, 2010 | 04:01 PM
hellsoldiers08
bump to help fix problem.
Old Aug 18, 2010 | 04:08 PM
NISMO937's Avatar
NISMO937
did you ever get that oil psi problem fixed
Old Aug 18, 2010 | 04:12 PM
NISMO937's Avatar
NISMO937
gunn nissan replaced the sensor
but my psi is still around 5 at idle
told me its hard to read that low they
are full of **** cant fix the problem
Old Aug 18, 2010 | 04:20 PM
hellsoldiers08
oil psi problem?? i dont think i ever had one.... unless i never noticed.
Old Aug 18, 2010 | 08:27 PM
hellsoldiers08
i had one of my friend that said it could be that the injectors are dirty :/ im like hmm i wouldnt think so for a 2590mile car ...... plus i put some sea form at 15k or so which idk y i did just listen to my dad lol. His cars have always seemed to run fine.
Old Aug 19, 2010 | 11:27 AM
hellsoldiers08
bump
Old Aug 19, 2010 | 12:45 PM
musubi's Avatar
musubi
It sounds like your rpms drop right when your a.c. fan turns on. Maybe it's drawing power to start the fans then levels off again? It would sound logical and maybe normal, but ,either way, if you weren't having this earlier then obviously something's not right.
Does it happen with the fans and A.C. off?
Old Aug 19, 2010 | 03:43 PM
hellsoldiers08
ya, same thing. it doesnt matter which way. All i know i had this car for a couple of years(brand new 07) and it has never done this on a start. Also, i dont think it has anything to do with my sound system either sense ive had one in there 6 months after i got the car.
Old Aug 21, 2010 | 06:25 PM
Q8y_drifter's Avatar
Q8y_drifter
my HR in my 2008 G35 sedan does the same thing. Every HR I've seen starts in a similar fashion. Mine's been doing it since the day I bought it and I currently have over 30K miles on it. I wouldn't worry.
Old Aug 21, 2010 | 06:35 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Looks normal to me. It is just trying to get up to normal operating temp quicker. My HR goes up over 2k sometimes after cold starts.
Oh, and lol at thread title:
Old Aug 21, 2010 | 06:43 PM
Waiz's Avatar
Waiz
^Beat me to it
LOL
Old Aug 21, 2010 | 06:50 PM
djamps's Avatar
djamps
Looks like nothing to worry about. With a full custom uprev tune (e.g. $$$) you might be able to iron it out a bit but why even bother...
Old Aug 21, 2010 | 09:38 PM
hellsoldiers08
well, thats what i dont get is it had a tune for tp and cat back and when i got it re-tuned for intakes(long tubes) and y-pipe it just started doing that :/ that the ???? about all of this.
Also i had this car sense day one(3miles on it) and it never did that till recently and ha ha sorry about the title lol.
Old Aug 22, 2010 | 05:58 AM
Chris@FsP's Avatar
Chris@FsP
It is possible that your tuner modified your idle tables while they were in there. Osiris allows you to plot idle speed vs. coolant temp.
