ARC Oil Pan AOPZ34 / VQ35HR compatible
Old Oct 26, 2010 | 12:48 AM
FastGreg's Avatar
FastGreg
Default ARC Oil Pan AOPZ34 / VQ35HR compatible
Hi !
Does anyone can confirm us that the ARC Oil Pan AOPZ34 for the 370Z, http://www.arcinter.co.jp/savra/z34/index.html , is compatible with our VQ35HR ?
As I understand Greedy's one are...
I already asked ARC, but no answer.
Thanks for the help
Old Oct 28, 2010 | 02:39 AM
0jiggy0's Avatar
0jiggy0
The VQ35HR and VHR37 are supposed to share the same block. So it should work. Maybe ask one of the vendors who work on them often(GTM, Forged) If they actually are exactly the same.
Old Oct 28, 2010 | 10:58 PM
Q8y_drifter's Avatar
Q8y_drifter
I just checked the Z33 and Z34 FSM's. They're identical.
Old Oct 29, 2010 | 12:00 AM
FastGreg's Avatar
FastGreg
I know that OEM oil pan are identical between the 370Z and the 350Z HR, but I don't know if the other parts allow to instal the ARC Z34 oil pan to the 350Z HR (like the sway bar for exemple...)
ARC Z34 Oil Pan:
And here picture of the 350z VQ35HR:
Old Oct 29, 2010 | 01:32 AM
Q8y_drifter
hmm.. I don't know actually. I have a G35 HR so we have the new chassis and subframe like the 370Z. The front sway bar on our cars is close to the oil pan. Since the ARC pan is bigger from the sides then it may fit the Z33 HR depending on how far the sway bar is. If you have a picture of the Z33 sway bar so we can compare the distance with the Z34, then maybe we can figure out if it fits.
Old Oct 29, 2010 | 01:39 AM
Q8y_drifter
Here's a pic of a stock 370Z. The ARC oil pan only adds a little to the size compared to stock. I don't think you will have any problems at all.
Old Oct 29, 2010 | 04:32 AM
FastGreg's Avatar
FastGreg
Thanks for help and advise
burglapfd
Dec 6, 2020 01:04 PM
