catch can
Old Nov 9, 2010 | 10:08 AM
08sleeperz's Avatar
08sleeperz
Default catch can
Hello everyone. I was wondering if anyone had install tips and/or pictures of a catch can for the hr I've been wanting to install one due to the high amount of blow by these motors have but I'm not sure where I gotta hook up the hoses. Any help would be appreciated, thanks in advance
Old Nov 9, 2010 | 05:24 PM
dirtbikr's Avatar
dirtbikr
Your car and you can do what you want, but it is no where near a necessity for a N/A application. If you're blown then sure, but the negligible blow by we have is nothing. Nevertheless, when I typed in catch can in the search box I got a lot of results...
Old Nov 10, 2010 | 10:35 AM
Cali-Darkness's Avatar
Cali-Darkness
I picked up an ARC Catch Can and I didnt get much help around here neither
Old Nov 10, 2010 | 10:39 AM
350ZTheStandard's Avatar
350ZTheStandard
catch cans are mostly for cute, especially ARC.
Old Nov 10, 2010 | 06:31 PM
08sleeperz's Avatar
08sleeperz
Actually I've heard quite the contrary for the HR. I've heard and observed first hand that there is a significant amount of blow by especially under hard use. And I too typed in catch can in the search bar and got many results but found nothing pertaining to the HR
Old Nov 10, 2010 | 06:33 PM
08sleeperz's Avatar
08sleeperz
Not what I've heard. The HR has quite amount of blow by and over time will cause sludge buildup and other unwanted consequences. I'm not in it for the short run, I plan to have this car for a long time.
Old Nov 10, 2010 | 10:58 PM
winchman's Avatar
winchman
Where does the sludge build up?
Old Nov 11, 2010 | 06:39 AM
ATL_Red_G35's Avatar
ATL_Red_G35
I know that for the DE, it has tremendous amount of blow-by. I have a Homemade catchcan on my G35 and it caught quite a lot of oil.
Old Nov 11, 2010 | 08:20 AM
R350Zz33's Avatar
R350Zz33
where does this gather plase tell me i have a 08 had it for 2+ years just hit 30k and i drive it hard every day and i have no blow by
Old Nov 13, 2010 | 07:17 PM
itsjiggajames's Avatar
itsjiggajames
How do you know you have no blow by?
Old Nov 14, 2010 | 02:03 PM
Q8y_drifter's Avatar
Q8y_drifter
I have a GReddy catch can but not yet installed since I need more hoses than supplied. You'll want to install it between the vacuum hose on the passenger side valve cover that goes all the way to the back of the plenum.
The HR has a lot of blow by gases BTW. Take a look inside your throttle bodies, plenums and manifolds.
Old Nov 14, 2010 | 02:59 PM
08sleeperz's Avatar
08sleeperz
Thank you for the response I was looking for. I'm not here to debate blow by. I know the HR has significant blow by and I want to install a catch can to minimize the longterm effects. Everyone may have a different opinion but I am set in my ways about this and I just wanted some direction about installing one. Good luck with yours
Old Nov 15, 2010 | 02:07 AM
winchman's Avatar
winchman
How can it have a lot of blow by when there's hardly any oil consumption? Mine has no noticeable change on the dipstick between oil changes.
Are you other guys with HRs seeing something different?
Old Nov 15, 2010 | 02:17 AM
0jiggy0's Avatar
0jiggy0
Thats because you keep your car under 3 grand.
Old Nov 15, 2010 | 04:57 AM
08sleeperz's Avatar
08sleeperz
Agreed. When I keep my car below 3grand which is usually during daily use, I don't burn much if any oil. But, if I run it hard, I deff burn oil. I checked my dipstick after making about 6 passes at the strip and I had lost oil.
Old Nov 15, 2010 | 10:05 PM
dirtbikr's Avatar
dirtbikr
Time to bring it in for a consumption test if that's the case. I used to run 30 - 40 passes over a weekend and a few high speed runs and never dropped on the dipstick. This is a farce. If it was needed that bad it would have come from the factory. Whatever blows through would get burnt anyways and no ill effects would come of it. It's car bling.
I have, it's cleaner after 60k miles than almost any other car I have seen besides our civic. I don't baby my car all the time either, it's a fun car, have to have some fun with it
Old Nov 15, 2010 | 10:56 PM
bardabe's Avatar
bardabe
I'm With dirtbikr I beat the hell out of my car and eh no consumption here guys. catch cants for the HR, only when boosted otherwise useless.
Old Nov 16, 2010 | 02:25 AM
0jiggy0's Avatar
0jiggy0
I haven't noticed a drop gone either. But maybe some people aren't using the correct oil or something.
Old Nov 16, 2010 | 09:08 AM
bardabe's Avatar
bardabe
yeah I think that might have something to do with it, I use European Mobil 1 & Castrol Religiously.
Old Nov 16, 2010 | 11:25 AM
08sleeperz's Avatar
08sleeperz
This isn't some made up bs. Its proven fact, check out other catch can threads with pics and you'll c that oil accumulates in the catch can. Sure it may only be an ounce or so over the course of an oil change but I'd rather have it in the catch can than in my intakes or wherever it gets to. Guess I'm just **** like that.
