HR cel light fix with test pipes and hi flow cats
Old Apr 8, 2011 | 11:55 AM
  #41
Junkster's Avatar
Junkster
Originally Posted by kramykram
thats funny i have used brillo in 2 sets of test pipes and the same set of high flow cats twice also with no problems.
I did mine about almost 1-2 months ago. So far im at 700 miles with no CEL...
would be nice to find a permanent fix. I agree about the hole being too big, would be nice to have some kind of solid peice that you could drill out with a very small hole..but i duno if too small would even work though...
Old May 10, 2011 | 10:47 PM
  #42
R350Zz33's Avatar
R350Zz33
im gonna retry the non foulers
Old Jun 10, 2011 | 03:02 PM
  #43
NISMOtuner's Avatar
NISMOtuner
good luck figuring out a permanent fix for this big problem. we need one. theres gotta be something that'll work. have you talked to sharif@forged to see if he had any ideas? just a thought.
Old Jun 11, 2011 | 11:17 AM
  #44
kramykram's Avatar
kramykram
lol i will never talk to those guys @ forged again. id rather spend the money to learn to tune with osiris than ask them for anything.
Old Jun 11, 2011 | 11:32 AM
  #45
KingBaby's Avatar
KingBaby
Hardest Setting
I still haven't got a check engine light.
Installed myself
I don't baby my car either, I did get the light once before tune. Cleared it haven't seen it since!
Old Jun 11, 2011 | 12:41 PM
  #46
NISMOtuner's Avatar
NISMOtuner
Why u say u won't talk to forged again? When it comes to tuning, I swear by sharif. I build my own cars but tuning always will go to forged!
Old Jun 11, 2011 | 05:45 PM
  #47
kramykram's Avatar
kramykram
I won't say at this time. But when the time is right it will be known
Old Jun 13, 2011 | 11:40 AM
  #48
Junkster's Avatar
Junkster
My CEL came back on for a short period and then turned off by itself. I check the codes and it was for the same codes as before...but wonder why it came on and off? wierd... lol
Old Jun 13, 2011 | 08:25 PM
  #49
AadosX's Avatar
AadosX
So you're saying that the code was still saved on the ECU but the light was no longer on? That is very odd. I've never seen a code for these turn off by itself.. sure the battery didn't go dead or anything?
Old Jun 13, 2011 | 08:52 PM
  #50
Junkster's Avatar
Junkster
Well I did reset the ecu when I did the defoulers and Brillo fix...rode Around for about 700-800 miles and then the light came back on....then the light just shut itself off after about 150-250 miles or so...I didn't even notice it for a while lol...I never cleared the codes when I checked em with my scanner either...which is another reason It was wierd....
I was under the same impression as you...guess that's not the case tho?
Old Jun 29, 2011 | 11:38 AM
  #51
OMG35S's Avatar
OMG35S
Bump for a fix! Any updates?
I have a 2007 Infiniti G35s Sedan with the HR motor. GTM RTP & Stillen CBE
I'm throwing P0420 and need a fix. I'm running GTM RTPs and they already have the extended bung on them. You think I'll be fine with just added some stainless steel wool or should I add another set of defoulers?
If I do both, do you guys have any pictures of how you guys packed the defoulers?
Thanks!
Adam
Old Jun 30, 2011 | 04:26 AM
  #52
kramykram's Avatar
kramykram
nope just add the steel wool. im still working on this and a bracket to get rid of the csc when i goto replace my clutch and flywheel this summer. but yes stuff the hell out of it till you can barely blow thru it. if your cheeks don't hurt you didn't stuff enough
Old Jun 30, 2011 | 07:22 AM
  #53
OMG35S's Avatar
OMG35S
Where exactly should I stuff it?
https://my350z.com/forum/attachments...fouler-024.jpg
Behind the little hole right? Around how much steel wool should I use? Around - 1/2" x 1/2" cube?
Old Jul 3, 2011 | 11:52 AM
  #54
srsairbags's Avatar
srsairbags
got CEL today . . after a year almost of running berk HFC with nismo S tune exhst . . . cleared it . . . hasnt come back yet . . . any fixes ? ?
Old Jul 6, 2011 | 09:41 AM
  #55
tribal_visionz's Avatar
tribal_visionz
So does a reflash/tune get rid of the CEL.
Seems to be most HFC are the only ones that stand a chance.
Old Jul 6, 2011 | 09:46 AM
  #56
Junkster's Avatar
Junkster
With uprev they can turn the code off yes...
Old Jul 6, 2011 | 11:08 AM
  #57
AadosX's Avatar
AadosX
For the record I have ART Pipes with no CEL. I've had them for about 1000 miles now.
Old Jul 6, 2011 | 11:44 AM
  #58
Junkster's Avatar
Junkster
I have a budy of mine that has Berk TP's and he never ended up with a CEL, i think some people just get lucky
Old Jul 6, 2011 | 01:34 PM
  #59
AadosX's Avatar
AadosX
Well I had Berk TP's before these and I instantly got a CEL heh.
Old Jul 6, 2011 | 06:10 PM
  #60
kramykram's Avatar
kramykram
take the 02 sensor out, stuff it really good in each defouler. stuff it so you can barely blow thru it. after you have it like that. stuff it lightly almost to the top. then screw the o2 sensor in. this will help to keep the packed steel wool from blowing out.
